06 Sprint ST gas key cover issue - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 08-28-2006, 07:25 AM   #1 (permalink)
sds
Any one else have the problem of NOT being able to flip up the key hole cover on their gas tank? Mine has found a way to "stick" in the closed position AGAIN, and this time, I am unable to work it free. So now I have an empty gas tank (barely made it home) and I guess I will have to remove the whole assy to put enough fuel in it to get over to the shop.
Any inputs greatly appreciated!
sds
"Under certain circumstances, profanity provides a relief denied even to prayer." - Mark Twain
sds is offline   Reply With Quote
Old 08-28-2006, 01:31 PM   #2 (permalink)
Favourite Bike: 06 Sprint ST ABS red
iceman's Avatar
havent of that before - must be a faulty cap.Easily replaced though - under warranty of course :-D
iceman is offline   Reply With Quote
Old 08-28-2006, 03:59 PM   #3 (permalink)
Yikes, that's pretty messed up. I guess you could try to whack it gently with a rubber mallet or something, in case it came out of alignment. Maybe shoot some compressed air, in case some crud is trapped underneath that is blocking it shut. WD-40 maybe? I wouldn't jink with it too much though, since it should be a warrranty replacement, and if you mess it up any further the dealer might just refuse to cover it under the warranty. Do you have AAA with RV/Motorcycle? If not, I'd highly recommend it (some people have the AMA coverage with towing, and I've heard good things about them too). You get four tows a year, IIRC, so it's probably worth it to use one.
Haddi-Man is offline   Reply With Quote
Old 08-28-2006, 09:31 PM   #4 (permalink)
Thats a NEW one....take it to your dealer....WARRANTY issue. Oh, but your low on fuel. HMMMMMMM????
Still not fast enough...
upnet is offline   Reply With Quote
Old 08-28-2006, 10:12 PM   #5 (permalink)
I'm with Haddi-Man. I just posted about the same thing on the other forum you posted this at. WD-40, tap with a mallet while lifting up on it may get it back into alignment long enough to put a little gas in it to get to the dealer. I wouldn't fill it up until after they have a chance to work on it.
bareyb is offline   Reply With Quote
Old 08-29-2006, 07:29 AM   #6 (permalink)
sds
As I stated on the other forum, bareyb was spot on. a bit of lube and it works fine. no need for a mallet either :-D Even though i was at the coast for four days, i had no issue w/ it. but when i got home and washed it, that is when i had the problem. probably pushed some dirt down into the hinge or something. it's sorted now. thanks again!
cheers,
sds
Ignition key issue kingpinnh The Rocket Science Forum 8 03-08-2007 10:02 PM
1050 gas gauge issue Cabinetman Sprint Forum 9 11-09-2006 01:11 PM
Gas Evaporation Issue aldtech Trophy 1 09-20-2005 11:23 PM
05 Gas mileage issue viper3256 Sprint Forum 10 07-29-2005 06:17 PM
Allen Key in Side Cover? bosoxrider Twins Talk 9 07-03-2005 10:23 AM
