Scottius...
Your idea for the straps is exactly what I did. I went to a local sporting goods store and bought 4 of those clips (QDs ???). The rear straps tuck nicely under the seat when I unclip the tank pad. The straps in front were not so easily hidden. After unclipping the tank pad, I can tuck the clips and straps behind the fairing, this probably wouldn't work on an ST though. I did consider buying two more clips for the front straps that would be used to quickly remove the straps from around the frame, but find that tucking them behind the fairing works good too. This enables me to go from nothing on the tank, or having the pad on the tank, or having the pad and bag on the tank all via the QD clips...
In fact if you look in my photo album, you can see the clip/strap tucked under the fairing in most of the side views (after you open the pic, you need to double click it to get the large image), but I will post some better pics this weekend that show how I did it and how I hide them.
Don
[ This message was edited by: vdlcinc on 2004-07-02 12:02 ]
Don
'01 Sprint RS (over 100K miles and still going)
'07 Thruxton (my new baby)
