I doubt the seals in a windshield washer pump will tolerate petroleum based products. They would probably swell and seize the unit. I purchased the correct solenoid pump from the same company as the Hawke Oiler uses, but have not finished mounting it up. I got a fuel tank from an RC Plane for an oil tank. My first idea was to just modify the dipstick to double as an oil pickup and use the oil from the engine. By using the dipstick I can set it up so it's impossible to remove to much oil from the engine. But since I check it regularly it wasn't really a big deal to me. You could also just use a correct size banjo bolt as the drain plug and tap it that way.
I didn't just want to use an on-off button (not trick enough for me) so it hasn't gotten done yet!
PS That pump is EXPENSIVE! To buy one (at dealer pricing)..........
Wait for it..........
$76.00!!! Like buying genuine Triumph parts! :wow:
And here it is.......
EMX-08 Piston Pump
At least it's a quality piece!
[ This message was edited by: Stlakid on 2006-08-15 00:20 ]
