Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
BikeBandit
Old 08-09-2006   #1 (permalink)
Favorite Bike: 99 Sprint ST
Other Motorcycle: 01Honda XR400
Just fired my '99 ST up after 2 weeks of no riding. Immediately noticed that the Engine Management Malfunction Indicator light stayed on after the start. Pre-start I checked the oil level and coolant and they were fine. rode the bike for 5 miles to be sure it wasn't the battery needing a charge. Light is still on, bike seems to be running fine. I did notice, however, that the odometer ticked over 24,000 miles exactly when I wheeled it out of the garage to start it up. Anyone have an idea of what the issue may be? Thanks in advance for any help.
EriePark is offline   Reply With Quote
Old 08-09-2006   #2 (permalink)
The computer will usually reset that light after the bike has been started/run thru several heat cycles. Mine would do that if the battery got low and/or I removed the battery for some reason. Ride it a couple of days before you assume anything worse.
playinthestreet is offline   Reply With Quote
Old 08-09-2006   #3 (permalink)
Favorite Bike: My '04 Sprint-ona
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Hi,
Plaayinthestreet's right. It should go out after three complete heat cycles. Start from cold, run to normal, cool down to cold.... 3 times and it should go out. If it hasn't then start thinking about a trip to the dealer.
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 08-09-2006   #4 (permalink)
Thanks for the info! Actually off to dealer in a couple hours anyway for fuel sender replacement and recalls. They agreed to hook it up to the computer and be sure nothing is wrong for free. Again, Thank YOU!
engine management light ??? tarmacrat Speed Triple Forum 2 04-29-2007 02:14 PM
Engine Management Light gstar Sprint Forum 1 08-30-2006 04:06 PM
Engine Management Light-Thanks Rudcluti Sprint Forum 0 05-19-2006 07:07 PM
engine management light on. banni955 Modifications & Workshop Talk 2 08-28-2005 07:58 PM
Engine Management Light! britishbulldog Speed Triple Forum 1 05-16-2004 10:18 PM
