:::low beam & high beam on a '06 Sprint??::: - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-25-2006, 10:18 PM   #1 (permalink)
Favourite Bike: 2012 Yamaha Supa10
hANNAbONE's Avatar
Other Motorcycle: 2006 Speed Triple
Extra Motorcycle: 2002 Aprilia Futura
Need to know the model (H4??) for the low beam and the high beam on the 2006 Sprint ST??
anybody help me please.!!
TIA
hANNAbONE
... where I-80 & I-35 kiss ...
Des Moines, Iowa
'12 SinisterBlack Yamaha Super Tenere' XT1200Z
'06 White Triumph Speed Triple
hANNAbONE is offline   Reply With Quote
Old 07-25-2006, 10:34 PM   #2 (permalink)
hi, nice bike, heat issue is a major problem you should have the upgrades already on an 06 model,
Headlights are H7 55W can not get stronger globes but able to use plus 50 which are brighter not stronger, same globe for low and high beams
cru_sin is offline   Reply With Quote
Old 07-26-2006, 02:18 PM   #3 (permalink)
hANNAbONE's Avatar
Reason for asking is because I'm thinking of plugging in a coupla Xenon bulbs...in the low beam
They'd run longer and brighter with less heat and less wattage...
Anybody already doing this??
I had a Hella HID/Xenon on my BMW and loved it..
I've been reviewing several different ones on the websites--
XenonKing etc...
What your take on this??
Is there room to fit the ballast etc.?
hANNAbONE
Des Moines, Iowa
Old 08-14-2006, 05:09 PM   #4 (permalink)
Favourite Bike: Sprint ST
So, how'd you do? I was thing about replacing the brights since to me its useless.
basco is offline   Reply With Quote
Old 08-14-2006, 06:52 PM   #5 (permalink)
huc
Bulbs are H7 for all three as noted in the manual and stamped in the plastic on the clear front lens. First thing I did was swap out the stock bulbs for PIAA H7's for all three bulbs. Better light, same wattage, really like them.
huc is offline   Reply With Quote
Old 08-14-2006, 10:39 PM   #6 (permalink)
Aske's Avatar
Kinda on-topic: I finally had my first decent night ride on the Sprint. I can't say that I'm too keen on the headlights. Nice horizontal cut-off, but they don't seem to illuminate particularly far down the road. Road-surface lighting gets even worse when the bike leans. The high beam also doesn't add much in terms of reaching farther ahead of the bike.
Any solutions, other than +50s or PIAA replacements? Is there any aim adjust to be had?
"Try to become not a man of success, but try rather to become a man of value."
Aske is offline   Reply With Quote
Old 08-15-2006, 08:55 AM   #7 (permalink)
huc
I adjusted the aiming on both the low and high beams. The manual as a full description on where the adjust screws are. They are bit of a pain but not too bad. I adjusted the vertical adjustment on all three up to throw a bit further down the road. I aimed the lows just a bit more outward but not much.
There was thread somewhere here that discussed the particulars that might also be helpful.
Generally the manual walks through the specifics. I simply set the Sprint up in the garage on the center stand. Dropped the door and started making adjustments. Rode, came back, put the bike in the same spot and tweaked it.
STill not perfect but better than stock in my estimation.
Old 08-15-2006, 09:13 AM   #8 (permalink)
Favourite Bike: Sunset Red 06 Sprint ST ABS & Silver 05 Tiger
airrider03's Avatar
Aske,
I adjusted the low beams in a split fashion, yes, to me they were useless from the dealer floor.
Take the right side low and screw it high up into the air, the threshold way above the oncoming cars, then take the left side low and screw that threshold onto the oncoming cars hood deck height, just below the drivers eye level. What you get is decent illumination for the twisty roads from the right side low (the higher the better) and it does not blind the oncoming cars.
The center high beam is useless and the PIAA replacement sounds like something I will do. Also, I have motolights to suppliment the high beams, operated with the high beam switch to keep things simple.
Stay Still, and roll the Earth beneath your wheels...
airrider03 is offline   Reply With Quote
Old 08-15-2006, 10:51 AM   #9 (permalink)
Aske's Avatar
Thanks for the tips, huc and airrider03. I need to break down and grab a manual, so maybe this is the impetus I've been waiting for.
I saw the Motolights setup at the dealer and also checked them out online. But I was really hoping to get better illumination for less than a $300-$350 hit. You'd think THREE beams would throw some darn good light down the road.
Old 08-15-2006, 11:14 AM   #10 (permalink)
airrider03's Avatar
I have the motolights on the tiger w/ the 35w bulbs, they nicely fill in what the stock lights leave out. Pricey, but they were a gift.
They could save a collision at night.
I liked them so much I splurged for the 55w version in black for the sprint.
High Beam/Main Beam whatever headlight - ***!!!!!!! tuk Sprint Forum 24 11-18-2011 03:17 PM
Low Beam Out LondonSabre Sprint Forum 6 09-27-2007 11:47 PM
Low Beam - Out! ssjones Twins Talk 1 09-17-2006 09:38 PM
Low Beam - Out! ssjones Twins Technical Talk 5 09-16-2006 11:33 PM
Where's my low-beam? Rincewind Hinckley Classic Triples 7 07-31-2005 03:57 AM
