Hello All. My first post here. Hopefully I will give you all enough information for some good answers/advice. I have a 99 Sprint ST with 17300 miles, one of the early models (084XXX on the VIN, i've never had to learn the last three). I love the bike so far, got it only a year and a half ago and it has been running great until just last week.
Just recently my baby has been acting up on me pretty badly. She starts just fine and idles just fine for a while. However, I am not able to ride due the following issues: Take mind that these seems to occur in no particular order, other than it starts and idles fine at first:
1. The engine will idle fine after starting it.
2. The engine will usually cut off completely either when I put the bike in gear, before letting out the clutch. Or shortly after when attempting to get off the line.
3. The bike may or may not start again immediately afterwards.
4. If it does not start it usually will not even turn over. As in extemely low battery or something shorted or opened. Sometimes the lights will all go out as I attempt to turn it over.
5. If the bike didn't start immediately, usually within 10 seconds it will start turning over again and will start. On occasion when attempting to start the engine will turn over very slowly as in dying battery, maybe one or two turnovers every second or two. But a few seconds later after turning over slowly she may turn over just fine...and usually does, but then the entire process repeats itself.
I replaced the spark plugs with NGK iridium about two months ago. Cleaned out air filters, etc, changed oil about 3 weeks ago. Replaced chain a few weeks ago...(i know those don't matter, but just trying to show I try to take care of her as much as I can right now).
I have performed the following trouble shooting:
1.Battery measures 12.3v. At engine idle the voltage across the terminals is measuring about 12.5. At above 2000rpm it measures around 13.75v.
2. When the engine shuts off, if the engine will not turn over right away, I can usually hear the fuel injection system pressuring up (that little whining noise on the left just under the seat, then a click after a about 3 or 4 seconds).
3. I checked the three relays just under the right seat and swapped them around, since it seems the first is the fuel injection system pressure or something since it would not start when I took that one out. This had no effect, (I was hoping it was something simple like a relay)
Any information will help at this point. I can't even get it to my dealer to get it diagnosed at this point (Erico Motorsports, about 30 miles away), I have no way of getting it there and I can't even get the bike off the line right now. I am wasting valuable riding days here and starting to get pretty cranky about it...
Sorry the post is so long, but hope it helps with enough information.
TIA!!
