2001 Sprint Shift lever question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports Motorcycle.com
Old 07-25-2006, 08:29 AM   #1 (permalink)
Favourite Bike: '01 Sprint ST (RED)
Hokie's Avatar
Other Motorcycle: '99 Suzuki DR650SE
This has probably been asked before, but I can't find it if it has. I just purchased a very VERY slightly used (1487 miles) 2001 Sprint ST last week and I LOVE IT. The only thing I am having a problem with is the shift lever is too high. I tried adjusting it down by extending the shift lever rod, but the lever hits the rod before it is low enough for me.
As it sits now, I have to lift my foot completely off the peg to get it above the lever to downshift. Any help would be greatly appreciated.
-Hokie (Shane)
Hokie (Shane)
Hokie is offline   Reply With Quote
Old 07-25-2006, 09:14 AM   #2 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
If the adjustability is not helping, you can replace the whole lever linkage.
a 2000+ Daytona shifter is a direct retrofit, and is a direct connection to the transmission shaft.
a bit costly at $100 for a new part, maybe some breakers have a few. do a thread search for opinions and options.
daytona shifter on sprint
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 07-25-2006, 11:05 AM   #3 (permalink)
Hokie's Avatar
chefjpd,
Cool, Thanks. I like that...
Hokie (Shane)
Old 07-29-2006, 08:57 PM   #4 (permalink)
Favourite Bike: '03 S3
cruzin57tbird's Avatar
Hokie,
was that a lynchburg ST? if it was, you will save me a trip.
cruzin :???:
cruzin57tbird
cruzin57tbird is offline   Reply With Quote
Old 07-29-2006, 09:21 PM   #5 (permalink)
Should be an easy fix:
1) Locate the shift arm attached to the engine and mark the end of the shaft and the arm's position with a grease pen (or the like)
2) Remove the single bolt that attaches this arm to the shaft.
3) pull the arm off noting the EXACT position, then rotate the shift arm in the direction that places the shift lever in the desired position (either clockwise or counterclockwise two or three splines).
4) Re-install the bolt and test. If not in desired position, refer to step one.
As a reminder, you may also want to return the rod-ends back to where they were.
SPORT
Let's Roll!
My Photo Album
Sport is offline   Reply With Quote
Old 07-29-2006, 10:14 PM   #6 (permalink)
Hokie's Avatar
cruzin57tbird,
Yeah, that is the one. sorry!
I noticed a scary thing tonight though. I kept smelling gas and discovered the fuel line is leaking pretty bad. The scary part is the fuel is running down various parts and ending up on the other side of the bike all around the alternator.
I'm hoping it is the fuel line connector that was recalled and will be covered work. Love the bike so far.
[ This message was edited by: Hokie on 2006-07-29 20:16 ]
Hokie (Shane)
Need a shift lever 2bugeyez Speed Triple Forum 0 03-19-2007 10:53 PM
Shift Lever Fitch Sprint Forum 1 06-06-2006 09:28 AM
2001 Sprint ST Muffler question bhouston Sprint Forum 8 12-30-2005 05:49 PM
shift lever- @!&$$&% Longshot92 Maintenance & Workshop Talk 5 11-11-2005 07:37 AM
Question about lowering the gear shift lever. Triumph SuperSports 3 07-19-2004 03:50 AM
