Ok, so I wanted an accessory outlet I could use on my bike (specifically for my Magellan Gps) instead of that goofy european plug thing. So I went to Radio Shack and bought an accessory outlet and a wiring harness so I could plug into the pig-tail of my battery charger/trickler that is attached to the battery. Got everything hooked up all nice and clean looking - you can't even see the plug receptacle - and plugged in my Gps DC adapter. It smoked. Pulled it out, checked things and all *looked* fine, so I started the bike. Runs fine, just have the check engine light on now. So I unhooked the battery and touched leads for a few seconds and tried again. Check engine light. So now I check everything again and find I installed the plug that mates to the trickler plug wrong. Wrong in that it is a polarized plug and I used the wrong end of the harness. + to - and all. So I figure the smoke was the LED and diodes inside the adapter burning up. However, I do not know where to start looking for what I did to the bike.
Could it be a voltage regulator? I don't think I could have killed the battery but not sure. Any ideas or thoughts you may have will be appreciated.
thanx,
rash
"There he goes. One of God's own prototypes. Some kind of high powered mutant never even considered for mass production. Too weird to live, and too rare to die." - Duke, Fear and Loathing in Las Vegas
