Sprint RS fuel filler cap - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearOntario TourismNew BonnevilleHonda Powersports
Old 07-24-2006, 04:04 PM   #1 (permalink)
I've got a question. Recently I bought a 2000 Sprint RS. I've noticed that there isn't a seal around the fuel filler cap, so water can actually get inside the fuel tank. Granted, the filler cap seals itsself into the lower portion of the neck, but there's a small area that water can get through to the inside of the tank. There's about a 1/8" lip preventing water from going into where the fuel goes, however if the filler cap is opened, it could be extremely easy for water to get into the actual fuel tank.
Is this normal, or should there be some sort of seal around the filler cap (the opening part) that prevents water to get into what I'd call the over-flow area of the fuel tank? I'm pretty concerned that water can get into the tank when I pop it open to refill.
porsche996 is offline   Reply With Quote
Old 07-25-2006, 08:20 AM   #2 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
yes, this is a normal condition. But, there is a drain tube in the filler neck area. see those two holes on the lip around the filler hole? One is a tank vent, and the other is the water/fuel overflow drain.
The only problem would be if the hole becomes clogged. then any water would dump into the tank upon opening.
You could run a bead of silicone aound the bottom of the filler rim in order to seal it.
:-g
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 07-25-2006, 10:46 AM   #3 (permalink)
OK. That's good to know there is a drain, at least. It must be clogged, as water sits there for days... I'll check the line today and see what's blocking it. Thanks!
Water in my filler cap kyot Tiger Workshop (archive) 4 12-31-2008 07:51 AM
05 Sprint - blocked drain from fuel filler iceman Sprint Forum 4 07-28-2006 04:18 PM
Billet fuel Filler Cap chefjpd Maintenance & Workshop Talk 0 07-13-2006 10:09 AM
Water and fuel filler cap Glen-Tiger Tiger Chat 7 11-23-2005 02:08 PM
Sprint ST (03) Water in fuel filler. perfectweb Sprint Forum 5 06-01-2005 04:45 PM
