Do you have heated grips? If not, you can put a powerlet in the panel blank on the left front fairing. You can wire it to the factory grip connector.
If you do have the grips, you can mount a powerlet just above it, and wire it to the switched power lead from the grips. The switched lead only triggers the relay, so carrys no real load.
OR you can hardwire the cradle to the said grips connector.
good luck.
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
