Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 06-21-2006   #1 (permalink)
I have a 01 Sprint and around 75 mph there is a buzz in the bars.I can't ride 40 miles without my hands getting numb. I have the standard grips on there that came stock, but i am wanting to get foam grips. I have heated grips so i dont know if that will work. Would i have to disconnect the heated grips somewhere? Because the wrap has stuck to the inside of the grip. Has anybody had this problem? The tires i have now are 5500 miles old and i have new avons i am putting on this weekend. Hopefully that will fix the buzz If not i thought of putting a couple of rubber o-rings under each handlebar where they mount to the triple tree. Any suggestions would greatly be appreciated . I am taking trip up to North Carolina to the Blue Ridge Parkway and Deals Gap etc.. So i need to get this problem fixed as soon as possible.
triumphstluster is offline   Reply With Quote
Old 06-21-2006   #2 (permalink)
Favorite Bike: All of them
NinjaRAT's Avatar
Other Motorcycle: '07 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
I've heard of a few different remedies, but none that I have personal experience with (someone else might be able to elaborate):
1. Gel grips; but you might have a problem with your heated grips.
2. Bar-end weights. TwistedThrottle.com has a few options here, though I've heard of others. This is probably your best bet.
3. Sand or buckshot poured inside your clip-ons. Might be more of an urban legend, than not. :???:
Personally, I just use my Throttlemeister to give my hands a rest, periodically. That seems to work for me, at least.
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
NinjaRAT is offline   Reply With Quote
Old 06-21-2006   #3 (permalink)
Favorite Bike: '03 Sprint RS
steventhechef's Avatar
Sometimes the buzz is caused by a loose chain. Often through the footpegs, sometimes through the handle bars (being an extremity).
Worth a look :???:
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is online now   Reply With Quote
Old 06-22-2006   #4 (permalink)
It sounds like a problem that is being caused by something not being as it should.
What is the condition of the headstock bearings and the front and rear wheel bearings?
Has the bike ever been dropped?
Are the chain and sprockets all good?
Hope you get it sorted.
Brett.
...always remember the lubrication...
My shiny red 675 morphed into a shiny (soon to be muddy) Scrambler!
Beach is offline   Reply With Quote
Old 06-22-2006   #5 (permalink)
The bike only has 5500 miles on it . So i would guess that the bearings would be in good shape. Yes i did drop at about 20 mph enough to bend the left clip on. I heated it up and straightened it out, but it did it before i laid it down. I read that some guys have had that a similar problem with the sorry ass bridgestones cupping causing a buzz but we will see. I am in florida so i really dont need the heated grips so maybe i can disconnect them somewhere?>
Old 06-22-2006   #6 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
triumphstluster,
I would also check the bar end weights are not loose. The purpose of these weights is to reduce or minimise bar vibes. If they have been replaced with something lighter than standard or are loose you will get handlebar vibrations.
Something else you could check anyway.
Good luck I hope you figuire it out.
Davem
DaveM is online now   Reply With Quote
Old 06-22-2006   #7 (permalink)
It's a pretty expensive solution, but Heli-bars reduce almost all of the vibes in the bars. I think it's because they're a tubular bar as opposed to the solid aluminum stockers. The extra adjustments are the big plus. In my opinion they're the best thing I've done to improve my bike.
TM
...miles & miles of Texas
mouse is offline   Reply With Quote
Old 06-22-2006   #8 (permalink)
Can we assume you keep the tires at a proper pressure?
"Dreaming of falling asleep, again"
my piccys
DragonDan is offline   Reply With Quote
Old 06-22-2006   #9 (permalink)
balance the tires lately ?
oldgoat57 is offline   Reply With Quote
Old 06-22-2006   #10 (permalink)
are you the original owner? check the sprockets, if teh previuos dropped the gearing the vibes will be harder now.
75 is about where I get my first onset with a 18 T but its tolerable.
when I had tubular bars I used a bar snake on my last bike and it almost eliminated all vibes.
"Exoriare aliquis nostris ex ossibus ultor."
REGULATOR is offline   Reply With Quote
Around the shanty w/ a good buzz on... BILLYSIM Twins Technical Talk 0 03-19-2007 03:59 PM
Will a TB Sync help the buzz? Yak Triumph SuperSports 3 08-09-2006 04:12 PM
Throttle Buzz Bigman Twins Talk 4 05-28-2006 01:12 PM
Handlebar buzz Panthermark Twins Talk 15 04-08-2006 11:32 AM
I got the buzz! MikeRokkit The Rocket Science Forum 13 03-08-2006 04:37 PM
