Progressive Insurance
britishcustomsBikeBanditShopTriumph.combritishcustomsAdvanstarMotorcycleShowsSportbikeTrackGearTriumphPerformanceUSAMotorcycle.com Classifieds!CycleGear.comAnnitori Distributing
Old 06-14-2006   #1 (permalink)
Favorite Bike: 2000 sprint ST
Suncoast's Avatar
Other Motorcycle: 1996 KLR 650 for the dirt
Does anyone know the part # for the Caterpiller o-ring that works well for a cuise control? I've heard that you just slip it over the grip like a large rubber band and it works well for a cheap cruise control..
Suncoast is offline   Reply With Quote
Old 06-14-2006   #2 (permalink)
Caterpillar Part #: 8M4991
I use them on all my bikes.
[ This message was edited by: DFWBiker on 2006-06-14 12:35 ]
DFWBiker is offline   Reply With Quote
Old 06-14-2006   #3 (permalink)
Suncoast's Avatar
Thanks exactly what I'm lookin for!!
Old 06-15-2006   #4 (permalink)
Favorite Bike: '06 Tiger
JasonS's Avatar
Other Motorcycle: '03 Sprint ST
Keep in Mind that ANY ORING will work as long as it is the right diameter and cord thickness... I got a #321 oring from a hydraulic shop for $.38 and the JD ring will run a few bucks...
have fun!
JasonS is offline   Reply With Quote
Old 06-15-2006   #5 (permalink)
The difference is durability. I get the Cat o-rings for about $2.00/ea, but they last a few years before they wear out. I've had cheap $0.25 o-rings last less than a month before they needed to be replaced.
Old 06-15-2006   #6 (permalink)
JasonS's Avatar
DFW... the one on my bike is well over a year old with 12k on it... it is blacka nd cracked a bit but still holding in there well...
various rubber compunds have varying degrees of UV protection and YMMV...
Use what works for you would be the answer!..
Old 06-15-2006   #7 (permalink)
I used the Cat O-ring recently on a trip and had a problem with the ring slipping completely between the bar end and the grip -- had to stop and pry it out with a key. I think I need to adjust the throttle housing to reduce the gap -- should be easy, just haven't got to it.
My buddy with a Tiger had the opposite problem, his O-ring wouldn't stay in the gap because his gap was too small.
So you may need to do a bit of testing and adjusting, but it's easy and otherwise the O-ring works well.
Jack
AlaskaSprint is offline   Reply With Quote
Old 06-15-2006   #8 (permalink)
Favorite Bike: 2002 Sprint ST
deller4210's Avatar
That thing looks like a throttle condom! :razz:
deller4210 is offline   Reply With Quote
Old 06-16-2006   #9 (permalink)
JasonS's Avatar
Jack
Cleaning the grip and the oring to remove and oils is a good idea. I have to do that to mine every once in a while...
there are different cross sections ( cord diameter) available in orings, so you can alwasy source one that is thinner or thicker depending on the bike/grip etc that you have.
Cat-O-Ring Throttle Cruise Control JasonS Sprint Forum 18 06-02-2008 07:59 PM
o-ring cruise control tmarsh Sprint Forum 3 02-05-2008 06:02 AM
O-Ring Cruise Control Pictorial Description jxs2151 Sprint Forum 7 08-04-2007 05:12 PM
Order "Cruise Control" O-Ring Online jxs2151 Sprint Forum 18 08-03-2007 03:01 AM
O Ring Cruise Control? jstrain Sprint Forum 6 07-24-2007 12:56 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
