Motorcycle.comBikeBandit
Old 06-09-2006   #1 (permalink)
Hello,
I just noiced something weird, there are drip marks of some thick fluid coming out of where my rear tire meets the rim.
Also there's some dried out white depsit on the rim near the fluid marks. The white stuff goes off the rim with little finger ation.
What is this stuff, preservation fluid comng out?
The bike has 490 miles on it and I am taking it for service tomorrow, should i be freaking out at them because of this or?
Thanks
chamade is offline   Reply With Quote
Old 06-09-2006   #2 (permalink)
Favorite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
Sounds like the sealer that is put on the rim to help the tire bond to the rim. Might be the grease that they use to help the tire slide onto the rim during mounting. Is it greasy fluid or sticky fluid?
Any pressure loss?? if not, stop freaking, and clean the ***** off with WD-40.
I have enough money to last me the rest of my life, unless I buy something.
chefjpd is offline   Reply With Quote
Old 06-09-2006   #3 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
chamade,
If it was me I would not be worried I would imagine it is most likely the soapy gunk they use when fitting tyres, the whiter stuff is probably some coating that was on the wheel after manufacture and not competely removed.
I am quite sure you do not need to panick.
Checking pressures should reassure you.
Cheers,
Davem
Brake fluid ? Mp350 Twins Talk 5 08-04-2007 05:53 PM
Enduro type tire for Bonnie Black tinez35 Twins Technical Talk 3 06-03-2007 08:43 PM
Photoshopped Pic of Black Rims on Bonnie Black for Convict derek985 Twins Talk 24 06-24-2005 09:55 AM
brake fluid... dml955i Speed Triple Forum 3 06-18-2004 10:20 PM
radiator fluid? fwhite Speed Triple Forum 1 06-09-2004 08:12 PM
