Well it seems the first thread had 'issues' with the list and it's length so it was deleted. Unfortunately, it was done before I had a chance to save the data in the list :cry: So I'm recreating it again but this time I'm doing it under the Wiki Triumphrat Pages so that the length of the post won't make a difference (hopefully). And after playing around with it a bit, it seems like it'll be a much easier way to manage the list. If you guys wouldn't mind reposting your part numbers to this thread again, I'll see about re-adding it to the new list.
The new Part Number list is located on
Wiki Triumphrat <- [Edit] old link no longer valid. use new link below.
Right now, there isn't much on there as I'm a little busy and my list of part numbers is located on a different system. But I'll update it with the part numbers that I actually have handy in a day or two.
Hey Don, could you re-sticky this thread so that the link would always be readily available?
Thanks
[ This message was edited by: Panthers_Den on 2006-06-04 23:42 ]
Update to the location of the parts number list:
Here's the link to the new page: Sprint ST after market part numbers
You can also get to it by going to the Blogs section, then clicking on technical data and then scrolling down till you see the posting. :-D
