The center light is adjusted from the top, by removing the screen and the panel underneath. Its a small bolt offset to the right, if I remember correctly. Its a fine thread, so be prepared to crank away for a while. I experimented with mine quite a bit. Its very easy to end up possum spotting or illuminating a very bright spot on the road 20' in front of you.
Good luck!
Brett.
...always remember the lubrication...
My shiny red 675 morphed into a shiny (soon to be muddy) Scrambler!
