Extra Neutral 03 RS - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 06-03-2004, 01:52 AM   #1 (permalink)
I've got an 03 RS with about 15,000km on it. When I shift from 5th to 6th I have to really lift and I can feel two distinct clicks. If I let go on the first click it misses a gear. Having read the trials and tribulations with RS gear boxes I haven't stressed too much (small price to pay for such a great ride). Asked the dealer to check on it during the service and he said he couldn't notice it. :evil: Anyone know if this is anything serious?
Old 06-03-2004, 02:29 AM   #2 (permalink)
Main Motorcycle: 2002 Sprint ST
Extra Motorcycle: 1979 Moto Morini 3 1/2 in
You might try adjusting your shift lever down a bit. That might give you a more positive 5-6 shift.
Don
Old 06-03-2004, 07:25 AM   #3 (permalink)
Main Motorcycle: 2003 Sprint ST
After 30.000Km the gear box is now pretty much ok. But I have a recalcitrant 5th to 6th also.
I do have the bad habit to shift-up rather quickly... (@ 4200 rpm = 120Km/h) when cruising on highway (yuuuk :razz: )
At higher revs (= at illegal speeds for Belgium police standards) it goes smoother....
SpiderTex is offline   Reply With Quote
Old 06-05-2004, 10:49 AM   #4 (permalink)
My ST does the same thing. It seems to do it when I shift it like a weenie. It goes better when I concentrate to make a firm shift. It does make a hell of clunk when it finds the gear from the false neutral. It kind of scared me to let the clutch back out not knowing what gear to expect. No harm, it's always 5th or 6th.
Devo is offline   Reply With Quote
Old 06-06-2004, 03:36 AM   #5 (permalink)
You know, my '01 ST does the same exact thing... but I have a pretty balky shifter. Oh well... you get used to it.
burtonsimmons is offline   Reply With Quote
Old 06-06-2004, 09:33 AM   #6 (permalink)
Same exact story on my 03 ST. When it (I?) first did it the clunk was such that I thought I had damage. So, either we all do or it is a "feature" of the Triumph box!
_______________________________
Will this mid-life crisis end?
KayTee is offline   Reply With Quote
Old 06-06-2004, 12:12 PM   #7 (permalink)
Another technicque that has been done with much success is to pre-load the shifter with a bit of pressure maybe 1/2 of a normal shift then make the shift.
One other thing, I always use the clutch. The shifter forks weren't really made for speed shifting.
Don
Old 06-06-2004, 05:58 PM   #8 (permalink)
On 2004-06-06 11:12, dolson wrote:
<< stuff deleted >>
Don
I always use clutch too. But I do not pull it all the way when up shifting. I down shift with full clutch, and with blips for 2nd and 1st. Seems to go smooth. And I do find the solid "toink" rather assuring then the (most) Japanese flimsy "click" "did I shift, did the gear change, did anything happen down under??" No offense meant to our Ossy friends down errr... :-D
Never understood why on beemers they have an indicator of the gear they're in, that gear box is soooo noisy that you just know that you shifted...
Oh and YES this bike is awwwwesommmmmmmmmmmmmeeeeeeeeeeee..
:razz: sorry back from a sunny day trip of +- 350 Km I just love this bike and I had a BBQ after it, and a few Duvels And now I'm sipping on a nice single malt..; DAMN life can be great
Old 06-07-2004, 08:12 PM   #9 (permalink)
Nah, you guys have got it all wrong.
That's a "factory" installed fuel saving feature. Kinda like the old Saab 93's that had the ratcheting differential that allowed you to leave the car in gear, but literally coast down long grades. As soon as you rolled in enough throttle to match the road speed, the ratchet engaged and you had full drive again.
Let's say your riding through hilly terrain with good wide roads like the Interstate thru Pennsylvania or Kentucky or thru the Cascades in Washington. You "drive" up the hills in 5th or 6th and with little more effort than that "Half-Shift" you can now coast down the back side of the hill. Is'nt that clever of Triumph??? See, your saving gas. And we know that's good for the country. Anything for God, Country and the Queen, right??
Yeah, mine does that too sometimes. Like Don mentioned the "pre-loading" of the shifter goes a long ways towards a smoother and more positive shift. Although the shift is actually made when the clutch lever is only at 1/4 to 1/3 of travel, I STILL pull the clutch lever all the way thru to relieve the pressure on the clutch plates and shift forks.
I too have to admit to the occasional serious speed shift for grins, but I always feel kinda guilty afterwards. The Sprinter has been pretty good to me, the least I can do is return the favor.....
I''ve read some stories of the Ricky Racer types on the Daytonas/Speed Triples mangling the shift forks by constant speed shifting and it's quite a chore to replace the forks, drum and broken gears, shims, bearings. That means one thing....$$$$$ and oodles of it!!
I ride my sweetheart hard and fast, but like any mechanical device, I try to develop a mechanical empathy for the various systems and do what ever it seems to prefer.
Develop a feel for the firm but gentle coaxing for each shift and release of the clutch lever. It takes a wee bit of focus initially, but practiced focus becomes habit it time. When you get it right, you'll know it. Smooth, quick, and positive, each gear engaged with a strong pull of the motor right at the torque peak and rewarded with a nice little "snick" as each gear is engaged. Get a good handle on this and the gearbox should last as long as the motor which we all know is a pretty doggone long time if maintained properly.
In other words, if you beat up the gearbox, it's gonna beat up your wallet!!!
Dan'l
So. Calif.
See my photo album
yerguy is offline   Reply With Quote
Is the '07 worth the extra $$ vs the '06? mlavin00 Sprint Forum 8 05-23-2007 10:28 PM
how much extra hp? ozbon Club Cafe' 3 02-17-2007 08:47 PM
Extra parts WizardofAz Classic, Vintage & Veteran 5 12-26-2005 11:02 AM
extra seat triumphrdr Speed Triple Forum 3 09-25-2005 09:14 AM
