On 2006-05-13 00:31, Grrnt wrote:
Nup as I'm running mine in I've been sitting on about 120-140km/h (with the usual disclaimers as you mentioned), pulling about 5, 5.5 in top during the few runs I've had and thought it'd be interesting to see how much it'll loosen up as time goes by. Normally on a trip out on back roads I tend to sit on 140-150 so pulling 6 thou seems no worries. I guess I could check the manual but redline is about what? Do you find the power pushes all the way to the limiter or tails off and you change up a bit earlier?
Oh, you're still running in, seems strange getting up to 150+ and running in doesn't? :-D
Redline is 10K, I know the power drops off just short of that, somewhere between 9-9500 I think it is. As the power is very linear through the rev range you don't really need to rev to redline to get the most from the engine. Also I can't say I noticed a tail off as I approached 9000 or so, but then in second or third acceleration is so strong you wouldn't notice it unless it was a) lot or b) maybe on a track pushing very hard.
I tend to use 8500-10000 as a range to maintain speed/acceleration between corners in the tight twisties to save an extra gear change and get the engine braking into the next corner.
On hwy running I tend to short shift between 4-6000 and just use the engines prodigous torque.
I've currently got 11,500K on the Sprint and it revs freely and pulls with linear power, you do feel an extra boost around 6000. It feels lovely when that power comes on, the pulling power is incredible. Feels very similar to my ZZR11 or ZX9 in that regards.
I haven't noticed it reving more freely I suppose it will free up around 20000 like other bikes I've had, but considering it revs willingly now it's not something it really needs to perform.
The best thing about the Sprint is definitely the motors performance. the 05/06 has the pops and burbles on deceleration, the increased power and the lovely sounds of the triple under load......mmmm I wanna go for a ride now :-)
I've really do have a track coming up and haven't decided whether to take the ST or the RS. Mmmm decisions decisions.
Lucky b*stard, I've only got one bike :-) As it's my do everything including commuter, I tend to avoid track days on it. The RS must be pretty light and nimble on the track.
Russ
