Motorcycle.comBikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 05-12-2006   #1 (permalink)
I run a 2000 RS and recently upgraded my headlamp bulbs for a pair of H4 xenon extreme white bulbs and fitted a relay to have both headlights on together.
Their is a definite increase in illumination but I find myself looking further than the light shines.
Is their a way to adjust the headlamps as you can on a car so the light shines further??
dickieshep is offline   Reply With Quote
Old 05-12-2006   #2 (permalink)
Favorite Bike: 2003 Sprint ST
Other Motorcycle: 1970 Bonneville
Extra Motorcycle: 1972 Norton Commando
There must be adjustment on the 200 RS but I don't know if it is the same as the 2002-2004 RS and ST, on those models the adjustment is the same. The manual recommends removing the cockpit, I removed the nose fairing to adjust mine. There are four adjustment screws on the back side of the headlight assembly (I think they are hex head bolts). As viewed from the rider's point of view, turn the right upper screw clockwise to move the beam to the right, turn the left upper screw anti-clockwise to move the beam to the left.
There are two vertical adjustment screws near the middle of the assembly. Turn the vertical adjusters clockwise to lower the beam and of course anti-clockwise to raise the beam.
Hope this helps.
[ This message was edited by: unummyu on 2006-05-12 16:42 ]
~John~
My Photo Album
http://www.triumphrat.net/photogalle...m794/album451/
unummyu is offline   Reply With Quote
Old 05-12-2006   #3 (permalink)
Thanks for that, found them as described (thought they were to hold headlamps in) duhh.
Headlight adjustment.... KevyKev Sprint Forum 13 11-13-2007 04:41 PM
Headlight adjustment scspeed3 Speed Triple Forum 4 03-28-2007 03:29 AM
Headlight Adjustment English_Spanner Twins Technical Talk 10 10-08-2006 01:22 PM
Headlight adjustment madtowner Twins Technical Talk 10 07-06-2006 11:21 AM
Headlight adjustment Swiss-Tony Speed Triple Forum 0 05-09-2006 01:34 AM
