On 2006-04-28 11:26, iceman wrote:
John,
hopefully Ron is keeping an eye on this and will answer.
It is 03 ST (see heading) and the black plug in the 2nd pic looks to be brown/yellow.He said the gray plug in 2nd pic is red/yellow.
Iceman,
I guess I should have read the title for model info??? DUH
Anyway, with the exception of the black and red wires the others have two colors, a primary color and spots of an additional color, black with green, etc.
There is connector with a black and a black and green wire that runs to the fuel level sensor on the tank (I noticed the tank was off in the pictures). The only brown with yellow wire on the legend runs to ignition coil #1. There is a pink with red and a yellow with orange wired connector that goes to the SAI (secondary air injector), however, this is only used on CA models.
Hope this helps.
