Hi All,
I know that lots of you are suffering spongy front bake syndrome. I've read loads of the posts on this issue. I have tried a couple of the "fixes" listed in the posts as well as the surposed "fix" from triumph, which according to my dealer is to push the pistons back into the caliper one side at a time.
This is meant to clear the air which is apparently getting into the master cylinder via the rubber pipe from the resevoir.
While all of the methods have worked for a short period none have actually fixed the fault.
Do owners of japanese bike with Nissin brakes have to do any of this? NO!
None of the things I have read or been told by my otherwise very helpfull dealership is a permantant fix. they just aleviate the symptoms until more air finds its way back into the system. A fix should stop this air getting in again!
Has anyone found out the full cure?
As we shouldn't have to tie back the brake lever, bleed the brakes, push back pistons into calipers or anyother thing which just cures the symptoms for a short while, on a brand new, 8 grand bike.
Other than this issue the bike rocks, just love it.
Jeff
