Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBanditMotorcycle.com
Old 02-12-2006   #1 (permalink)
SR1
Ok, I just finished my front sprocket mod and I guess it was worth it. She will almost wheelie now in 2nd when shifting hard from first. I know if I dump the clutch in first at takeoff she will, but she always would. It seems a little faster, or maybe I was just hoping for that. We'll see.
I don't f'n wash it.
I don't f'n polish it.
I don't f'n wring my hands and worry about it.
I f'n RIDE IT.
SR1 is offline   Reply With Quote
Old 02-12-2006   #2 (permalink)
Out of curiousity what did your idle MPH come down to? I'm contemplating a switch to an 18 tooth front. I really notice the tall first gear on mine in traffic. Luckily though I don't have to spend too much time in traffic. Still, a little shorter first gear would be nice.
Have you done any other mods to affect performance?
Windblown is offline   Reply With Quote
Old 02-12-2006   #3 (permalink)
SR1
I'll let you know tomorrow.
I f'n RIDE IT.
Old 02-13-2006   #4 (permalink)
Has this affected your speedo? I think the speedo is driven by the gearbox and reads to high when the sprocket is changed? Or has the speed per revs come down proportionately?
BEL
Old 02-13-2006   #5 (permalink)
Favorite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
My idle speed is around 5-7mph if I remember correctly. The speedo is driven off the front wheel so no problems there.
My Photo Album
Stlakid is offline   Reply With Quote
Old 02-13-2006   #6 (permalink)
trafficfixr's Avatar
i live near NYC and this mod has made heavy traffic suck so much less than it did before. still sucks, but now it is manageable without feathering the clutch to keep from stalling or bucking. you can idle the bike and its not lurching toward the car in front of you anymore.
Many people think my Tona is a Ducati when they first see it. I tell them nope, this is way faster than any Duc.
trafficfixr is offline   Reply With Quote
Old 02-13-2006   #7 (permalink)
SR1
My idle is around 9.5 mph now. Was around 12. Today I did a 2-3" wheelie shifting into 2nd after I was running 1st really hard. 70 mph (indicated) is 4100 rpm in 6th gear, and you could go as far as about 67mph without lugging it in 6th now.
I did a top-speed pull just for fun. I had never gone this fast so I don't know if there was an appreciable difference, but I started at 80 and turned the fast knob all the way. I ran it up to 140 (indicated) and she pulled HARD all the way though. It pulled with the same torque all the way from 80 until about 138. At that point it started backing off a little, but not much. I let go of the grip and slowed down for the next turn.
140, or whatever it really was, happened in a BLINK!
I f'n RIDE IT.
Old 02-15-2006   #8 (permalink)
Favorite Bike: 2003 Sprint ST
BEL
not gearbox, but little rotary thing on the front wheel axle
SpiderTex is offline   Reply With Quote
Old 02-20-2006   #9 (permalink)
This thread is based on the 1050 ST. The Speedo is definitely rear wheel driven - if you put the bike on its main stand and put it in gear with the engine running the Speedo starts to register your road speed.
This means that although acceleration etc improves, the Speedo will still show the speed based on the old sprocket ratio.
So when SR1 was accelerating quicker up to an indicated 140mph, it was probably nearer 130mph.
Does anyone know a way around this issue? I would love to do this mod but my Speedo is already about 10% fast and this will just compound it.
BEL
Old 02-20-2006   #10 (permalink)
SR1
Bel, you are so right.
Now, I haven't gone looking for a speedo pickup, so I will take your (Bel's) word that it is on the rear tire, which is a problem for sure. I don't think changing the sprocket will compound the problem, as the sprocket really only affects the rpms, not the speed at which the rear tire travels.
Now, for a real-world report on speedo inaccuracy, I had my 1050 up to an INDICATED 150mph last week and I brought my GPS along. It registered a 132mph top speed. that's a 12% error. It's important to realize that the 12" error is not 12% all the way from 0 to 150mph. It's somewhat logarithmic. Your error at 1 mph is tiny. Your error at 30 mph may be only 1.5 mpm not the 3.6 that 12% would suggest. What would change the reading properly would be to move the pick-up outward on the rim slightly...I think. Anyone? Can this easily be done? We would have to move it so that the new position would report a 10-12% lower speed. Hmm..
I f'n RIDE IT.
Sprocket cover mod Caffeinated Twins Talk 14 04-07-2007 03:35 PM
Front sprocket cover mod RANCAM Twins Technical Talk 1 03-05-2007 08:50 PM
Sprocket Cover mod. zimtok Modifications & Workshop Talk 18 02-05-2006 02:13 PM
Front Sprocket Mod ScullDuggery Sprint Forum 28 01-04-2006 02:56 AM
