It took me about 4 hours to install. The hardest part was routing the wiring and the oil hose. I also had to splice in some wire for the pump and the reed switch. Otherwise, it really went quite easily.
Below are a bunch of photos (They are on the big side):
1) Is the reed switch. This is what read the magnet I put on the rotor to read the number of turns the wheel makes:
2) Below are the components. the box on the left is the routing box. the middle is the oil resevoir. The right is the pump. The breather tube is the white tube going from the oil resevoir to the back of the ST.
3) This is the control unit. The brain of the oiler. This is where you set the oiler. You can adjust this on the fly:
4) This is the dual oiler. It puts out a little bit of oil to each side of the chain.
5) This last image shows how I routed the oiler hose. It fit nicely within the channel on the chain guard for the rear brake hose.
If you have any other questions or want other pics. Let me know.
Tom
'01 Sprint ST
[ This message was edited by: thfwsf on 2004-07-06 19:13 ]
