Old 04-24-2004   #1 (permalink)
Finished synching throttlebodies today. When I finished and got everything buttoned up I took it for a spin. When I started the bike the engine light came on and stayed on.
Any thoughts? Only thing I can think of is when I turned the bike on to set the throttlebodies, I slipped a shim under the throttle plate. Unfortunately, I did that before I turned the engine on. Did that reset the throttle position sensor?
Unfortunately, after all the messing about, the bike has slightly improved throttle response at low revs but I still have the surge/miss at light load, part throttle. I checked the plugs while it was open. They all looked the same, light tan deposit, even distribution, no balck marks or crud, gapped just under .90 mm.
Any thoughts welcome.
BruceG
Sometimes I have to pay people to do it almost the way I want it, but mostly it isn't worth the hassle so I do it myself.
BruceG is offline   Reply With Quote
Old 04-24-2004   #2 (permalink)
The engine light should go off after three full heat cycles if the original cause for the light has gone away. I think you need to run it until it hits normal operating temp, then let it cool all the way down, etc.
Pittsburgh RAT Pack
www.pghratpack.com
garry is offline   Reply With Quote
Old 04-26-2004   #3 (permalink)
Did you reconnect the connector on top of the airbox. This is what got me a while back.
The 3 warm up cycles will turn the light off.
Fishtale
Fishtale is offline   Reply With Quote
Old 04-26-2004   #4 (permalink)
Thanks for the thoughts guys. Now that I think about it, I can't remember if I put that connector back or not. #$%^&*@, now I'll have to pull the tank again.
BruceG
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 08:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 08:18 AM
Got RS going, now engine light is on.... jellero Sprint Forum 13 12-18-2005 09:04 PM
engine light mosby Daytona Deliberations 2 04-30-2005 07:23 PM
Fuel light/Engine light zore Modifications & Workshop Talk 1 06-28-2004 11:52 AM
