Coolant hoses - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 01-03-2013, 03:16 PM   #1 (permalink)
Main Motorcycle: '01 Sprint ST
Redhouse's Avatar
Other Motorcycle: '08 Ducati Multistrada
Coolant hoses
How often should the hoses be replaced?
I have about 32k miles on my '01, and I have a bit of a coolant weep where the upper radiator hose connects to the radiator. I tightened the clamp up last year, and I thought it was good, until I took the fairings off and saw there was some more weeping and the level was a bit low in the recovery tank. I tried to tighten it up, but it just wont go any tighter.....so I'm guessing I need to buy a new hose.
Looking on Bike Bandit....These hoses aren't exactly cheap, and I should probably change all of them while I'm doing it.....no sense in replacing one now to have another one fail in a year or so.
Just wondering for those with older Sprints......have you had to replace your coolant hoses?
I will be flushing the coolant too.....and I need to flush the brake fluid too, but that's another topic.
Redhouse is offline   Reply With Quote
Old 01-03-2013, 09:03 PM   #2 (permalink)
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2000 Sprint ST
I cannot say that it should/shouldn't be replaced but this has been an annual winter event with the Thunderbird since 2006. For the most part I have ignored it since it is a weep and does not leak a bit even in very hot weather. Maybe try a new clamp? How do the hoses feel? If they feel soft when squeezed definately time to replace...
"You are either on something or onto something"........The Common Man
BRG-BIRD is online now   Reply With Quote
Old 01-04-2013, 12:47 AM   #3 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Coolant hoses are not a scheduled maintenance item. Doesn't mean they don't need replacing, just that they're not included on the checklist.
Cheers,
-Kit
Old 01-04-2013, 06:57 AM   #4 (permalink)
Main Motorcycle: 1999 Sprint ST
hdpegscraper's Avatar
Might want to check for corrosion build up in between the hose and pipe, preventing a good seal, before you buy new hoses.
hdpegscraper is offline   Reply With Quote
Old 01-04-2013, 08:54 AM   #5 (permalink)
Redhouse's Avatar
The hoses don't feel soft or "squishy", and don't look deformed at all. I'll go ahead and remove the hose in question to check for any corrosion before I go and order new ones.
Kit, thanks.... I did see that they are not on the schedule....was just wondering if anybody has just gone ahead and replaced all the hoses at a certain age or mileage on the bike.
Old 01-04-2013, 02:58 PM   #6 (permalink)
Main Motorcycle: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
I replaced mine last year as they were starting to go soft and when I compared them to the replacements, they were larger, showing that they had swollen. So that would be about 36,000 miles and 6 years. If that helps
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 01-04-2013, 03:23 PM   #7 (permalink)
Redhouse's Avatar
That does help...thanks Rexxy
coolant flush, can i run my engine to pump out old coolant?? sandslinger17 Speed Triple Forum 2 03-09-2012 10:07 PM
Silicone coolant hoses matress Daytona Deliberations 0 06-30-2010 06:21 PM
Coolant overflow hoses KitNYC Sprint Forum 3 04-11-2009 11:34 PM
Coolant + Hoses frider Sprint Forum 12 11-13-2008 11:01 AM
Coolant Leaks and Loose Hoses Shakey Street Triple Forum 1 12-14-2007 06:58 AM
