Plastic tank replacement - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 22 (permalink) Old 01-05-2013, 11:26 PM
DEcosse's Avatar
Originally Posted by Martin50 View Post
Did you have to rotate the tank in different directions to get the coating to fflow and cover all the interior surface?
Yes that is the only way you can coat sides and top
DEcosse is online now
post #12 of 22 (permalink) Old 01-06-2013, 11:01 AM
Main Motorcycle: 2006 Sprint
Other Motorcycle: 68 Bonneville, BMW R80RT
Extra Motorcycle: Yamaha YZ250
[[quote]QUOTE]
Half Brit,
Thanks for the link, I ordered the tank.The other tank at $240 had almost triple the shipping cost at $60 (compared to $23) so we both got the best price. Did you coat interior with epoxy before using? If yes, how did it go?
Also, I noticed you live in Ohio. I live in Chicago and belong to MSTA (Motorcycle Sport Touring Association). There's an MSTA member that I ride from Ohio and there is also an MSTA ride event in Ohio called Mailpouch Fly By. Let me know if your interested and I'll send you a link and my Ohio rider partner email if you like.
By the way, I'm 100% Irish but have spent a lot of time in the UK so we should get along.[
Cheers Martin50
Happy to hear you got the new tank purchased.I am replacing mine due to some nasty scratches that were on it when I bought the bike. I have not had any ethanol problems as of yet although when I left it off the bike overnight it grew to the point I had a devil of a time getting it back on! I have not installed the new one yet and it may be wise to coat it. Although I have bad memory's of coating a few steel tanks in the past. I have never heard of Caswell but will try to learn more. DEcosse"s post reminds me that once you start you better be prepared as there is no turning back! Hypurones post is interesting, as I thought POR15 is a rust preventative coating for steel?
Yes my mother is from London and I have visited the UK 5 times in my 52 years and have a strong attraction. My wife and I have always wanted to visit Ireland as well.
I live in Northwest Ohio in the Toledo area (flat). I am not familiar with the MSTA so please do send me the link, as I am increasingly looking for every excuse to spend time on my Sprint!
Halfbrit
Halfbrit is offline
post #13 of 22 (permalink) Old 01-06-2013, 11:16 AM
Main Motorcycle: Ducati Monster S4RS
Hypurone's Avatar
Other Motorcycle: 2010 Thruxton RS
There are different products from POR within the POR15 line. Some are designed solely as a rust preventative (is usually a paint on product) and the one I referred to is designed primarily to be impervious to fuels...
Chuck's Garages Thruxton
Camaro
Monster
'10 Thruxton RS 944cc - In the Faster Color
"You Were Really Flyin' When I Passed You Back There!"
Hypurone is offline
post #14 of 22 (permalink) Old 01-07-2013, 06:36 PM
Thanks for the info, I will check into it.
Halfbrit is offline
post #15 of 22 (permalink) Old 01-07-2013, 09:13 PM Thread Starter
Main Motorcycle: 2007 Sprint ST
Half Brit,
I'm slightly younger than you at 50.
Here's the Motorcycle Sport Touring Association site link.
http://www.ridemsta.com
It's a national association with local groups.
See event section on top of page banner for 2013 rides.
Also, see forums section, local forums for state groups.
There's one for Ohio. I can put you in touch with the Ohio leader if you're interested.
Good group, very experienced riders. You can participate as much or little as you like.
There's even a few Sprint riders.
By the way, more research is needed on tank interior coating. Casewell is recommending roughing up tank interior if it is smooth to get better expoxy coating bonding. Need to find out best method.
See the events section on the banner at to of page.
Martin50 is offline
post #16 of 22 (permalink) Old 01-08-2013, 07:13 AM
Thanks for the info Martin50, I took a quick look and it looks like something right up my alley!I will check out the site alittle better ASAP.
And I agree it would be time well spent to research the tank coating process fully before proceeding. Some of the problems I mentioned with coating steel tanks was poor adhesion, even after etching with acid.
Halfbrit is offline
post #17 of 22 (permalink) Old 01-09-2013, 01:55 PM
A couple questions on the coating process for DEcosse if he see's this,
Did you use the "hand-full of drywall screws" mentioned in Caswells instructions to rough up your tank? was it effective?
Did you use masking tape or duct tape to cover all the openings? How soon did you remove it after coating?
It looks like yours came out really nice.
Halfbrit is offline
post #18 of 22 (permalink) Old 01-09-2013, 02:24 PM
Main Motorcycle: Sprint RS,Black,04
frider's Avatar
Other Motorcycle: That one
Extra Motorcycle: Yorkie and Silky WOOF!!
Wonder...
Would it reduce the tank capacity by much, d'ya think?????
Chocolate Food of the Gods!!!!!!
frider is offline
post #19 of 22 (permalink) Old 01-09-2013, 02:57 PM
DEcosse's Avatar
... Did you use the "hand-full of drywall screws" mentioned in Caswells instructions to rough up your tank? was it effective?
I did not - I didn't want the screws banging up the vent tubes.
It seems to have had excellent adhesion regardless.
I did use a thorough cleaning procedure.
I did not use acetone - I think you would want to be cautious with Acetone on your finished paint, so removal will be tricky.
I used water with few drops of detergent initially - shook up tank really well and then rinsed several times really well
Finally used alcohol to remove any residual water and then left my heat gun blowing warm air through it to throughly dry.
Did you use masking tape or duct tape to cover all the openings? How soon did you remove it after coating?...
I did - actually several iterations during the process.
Best method I would say is - seal the filler neck and the level sensor port (I used a bung for the latter);
Pour resin mix in through the pump port and move around to coat tank, while avoiding position which will spill onto pump plate opening (or just go ahead and seal initially). It helps to have the pump plate port 'open' because you can see what you are doing. But of course will have to seal it up when you come to coat the area in that proximity.
Then use brush (as necessary) to 'paint' into some of the corners or the vent tubes, accessing through the pump plate opening;
then re-mask across the pump plate opening and continue to rotate tank to cover the areas close to the pump plate.
You can probably remove the tape after about 30 mins or so and trim up the edges of the openings as necessary with a blade, while it is still slightly soft.
If you have excess material, you can always remove it - although somehow I doubt you will.
Can't stress enough that it should be warm in the area you are working to ensure that it will flow.
I'm sure I would do this better the second time around!
If you have no plans to repaint the exterior, be sure you protect the paint adequately - especially if working inside the tank (with brush) you want to be sure you do not touch the exterior if you have any on your gloves - change gloves frequently. I would suggest you wrap tank with seran wrap so there is no danger of touching it with 'sticky fingers'.
Here are Caswell's own instructions:
Originally Posted by Caswell Plating
Application Instructions
All traces of oil and gasoline should first be removed by pouring about 1 pint of acetone or lacquer thinner into the tank, and rotating the tank several times to thoroughly sluice the sides with solvent. Dispose of the contaminated solution.
When recoating your gas tank from failed Kreem or POR-15 tank sealers, remove the old, failed coating using a paint stripper containing Methylene Chloride.
Place a hand full of drywall screws into the tank and shake them around vigorously for several minutes. These will dislodge any loose particles of rust. In the case of Fiberglass and plastic tanks, this will rough up the tank interior, improving adhesion.
Rinse out the tank with about 1-pint of acetone or lacquer thinner, then set aside and allow to dry. Use an airline to blow air into the tank to aid drying.
Apply duct tape or masking tape to any weeping seams, holes or porous areas. This will stop any Gas Tank Sealer from oozing out, and will allow it to bridge over the hole. Plug the outlet ports with putty or Play-Doh. Mix up the required amount of Gas Tank Sealer (one unit should treat two small motorcycle tanks or one large one) If you are only treating ONE small tank, then divide parts A & B in half. You could use a dipstick to gauge this.
In a separate plastic container (margarine tub etc.) mix the two parts together thoroughly for at least 2 minutes. Scrape around the sides to ensure all resin is blended together. BAD MIXING AND BAD MEASURING IS THE #1 CAUSE OF FAILURE!!
Pour into the tank, then immediately seal up the filler hole with Gladwrap and an elastic band. Swill the tank around in every direction for several minutes to obtain a good layer of Gas Tank Sealer over all surfaces. Remove the filler cap,Gladwrap seal, and pour out any excess. Allow to drain upside down for a few minutes.
If you have a built in fuel filter, blow air into the fuel line port for about 10 minutes. This will clear the filter of any Gas Tank Sealer.
Scrape off any excess with a sharp knife at this point (usually about 40-60 Min after mixing) Place the tank in a warm 70-90 f place and allow to cure overnight. In the case of alcohol fuels, allow 3-5 days at room temperature, or 24 hours at 120 deg f.
Originally Posted by frider View Post
Wonder.... Would it reduce the tank capacity by much, d'ya think?????
It will reduce the capacity by EXACTLY the volume of material that you pour in. Whole thing is 1 pt (US)
post #20 of 22 (permalink) Old 01-09-2013, 03:22 PM
frider's Avatar
lol............
great instructions......did see/hear of Caswell Steel tank coatings..in the UK..70's/80's.....improper application(s) had bits flaking off and blocking fuel filters/carb jets etc..........put me off, as I'm a lazy bugger at the best of times!!!!!!
( although I DID once spend a whole week with petrol/toluene?? and carb cleaner cleaning a bank of small 4 cylinder Mikuni's.......couldn't breathe after that !!!!)
as with most things, preparation is 97% of the job!!!!!!!!!
I'll stick to my Fuel additive/Water burner, see how it seems to be doing well...so far!!!!!
frider is offline
Plastic Fuel Coupling replacement sealant ? guswalken Sprint Forum 12 06-20-2012 07:40 AM
Plastic brake resovoir replacement Stebinners Air Cooled Twins Technical Talk 3 11-12-2011 04:02 PM
tank position on plastic-tank (and other?) 1050 Sprints CBLove Sprint Forum 9 08-02-2011 06:36 PM
Lucas Tail Light plastic lens replacement ondrej.glembek Air Cooled Twins Technical Talk 7 02-22-2011 03:37 PM
Replacement plastic Art Sprint Forum 1 03-30-2006 09:13 PM
