12-27-2012, 05:33 AM
Grand Prix 500 Main Motorcycle: Sprint ST (today)
Fork Oil Top Up
Hey all,
Left fork on my 06 ST has been weeping for some time. I haven't got time to change it until I have some time off in early Feb, but would like to add a few mm to the leg just to keep me going until then.
I have read all the fork rebuild threads, but can't find an easy answer to this. Is it possible?
Thanks in advance
NH
12-27-2012, 09:32 AM
Powerbike Main Motorcycle: Sprint ST 2007 ABS
You can certainly take the cap off, and drizzle some oil in there. The only problem is, you really won't know how much to add unless you take the spring completely out, and compress the leg fully.
In order to do this, you'd need to take the leg out, at which point you might as well change the seal.
I'd guess that if you overfill the leg, you'd run the risk of blowing the seal outcompletely
12-27-2012, 10:28 AM
SuperSport Main Motorcycle: '98 T595 Daytona
Posts: 1,040 Other Motorcycle: '01SV650S sold
Only you know how much oil has seeped out. I don't think a couple of mm are going to make a difference either way. I would be more concerned about the oil making its way down to the caliper pads. Perhaps a bit of dirt has lodged itself at the seal. Dirt bike riders use a seal cleaner to swipe the seal while in the fork to remove any debris that got under the dust seal.
12-27-2012, 11:09 AM
SuperBike Main Motorcycle: '08 Sprint ST
Posts: 1,701 Other Motorcycle: '08 Suzuki SV650K8 Extra Motorcycle: '70 Husq 360 cross
I would simple support the bike with the forks off the ground, pull both fork caps. Then, with leaving the springs in place, simply match the fluid level in the good side and quit while I was ahead.
Remember to re-set the length of exposed thread on the damper rods when re-installing the fork caps. I believe it's 10mm., but I don't have a manual handy.
Just a tip: If you use this method, just go easy! Adding 10cc's of fork oil with a graduated syringe will raise the oil level almost 10mm.! And it's a lot easier to add the oil, than get it out!!!!
12-27-2012, 12:07 PM
Immoderate Moderator
Site Supporter Legend Main Motorcycle: '04 Sprint RS
Posts: 11,298 Other Motorcycle: 2000 Sprint ST Extra Motorcycle: '77/'82 Suzuki GS550/650
What Bruce said about matching levels, and what Felony said about the seal cleaner. This is not The Right Way to do it, obviously, but I would think it would do you for a month or so.
Cheers,
-Kit
12-27-2012, 03:55 PM
Thanks guys - i know this isn't the right way, but it'll make me feel better until i get time to sling the front end and go right through everything.
Really appreciate the advice.
NH
12-27-2012, 04:33 PM
Job is done - matched the levels. Do I really need to replace the seals now?? (Joke!)
12-27-2012, 04:55 PM
Formula Extreme Main Motorcycle: '08 Sprint
Posts: 770 Other Motorcycle: '07 Ducati 1098S
Another happy ending thanks to collective experience. Up next, the sequel to 1050cc's fork adventures
12-27-2012, 04:57 PM
I would think about installing gaiters on the forks. That way you can let them fill up before adding oil to the forks.
12-27-2012, 05:43 PM
You aren't the guy who bought my last Suzuki, are you??? Sorry about that!!
