Advice on Brembo Caliper fitment - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-25-2012, 03:31 PM   #1 (permalink)
Main Motorcycle: 05 sprint st 1050
Other Motorcycle: Buell X1 lightning
Hi could anybody offer any advice on fitting brembo calipers to fit an 05 sprint st 1050 as my original brakes are really spongy and knowing Triumph UK the cost of the d675 coated pistons will be costly..and on previous bikes fitted with Brembo`s i`ve never had a problem...
milky is offline   Reply With Quote
Old 12-25-2012, 04:18 PM   #2 (permalink)
Main Motorcycle: '07 Triumph SprintST 1050
BigDanUK's Avatar
I'm led to believe its more of an issue with the master cylinder than the caliper or pistons. Why don't you look at alternatives?
Should be a lot cheaper.
2007 Triumph Sprint ST 1050
http://i.imgur.com/JU9cr.jpg
BigDanUK is offline   Reply With Quote
Old 12-25-2012, 05:02 PM   #3 (permalink)
Originally Posted by milky View Post
Hi could anybody offer any advice on fitting brembo calipers to fit an 05 sprint st 1050...
Is it really so hard to use the Google Search facility at the top right hand of this page?
Here are a selection of threads it took all of 3 seconds to find:
http://www.triumphrat.net/sprint-for...sprint-st.html
http://www.triumphrat.net/sprint-for...-calipers.html
http://www.triumphrat.net/sprint-for...o-upgrade.html
http://www.triumphrat.net/sprint-for...wap-maybe.html
DeanRider is offline   Reply With Quote
Old 12-25-2012, 06:01 PM   #4 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Deano at 3 seconds you are getting slow in your old age my friend!
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 12-26-2012, 06:18 PM   #5 (permalink)
Hi thanks for he reply Deanorider with the photo, that looks good and have been looking to source some Brembo calipers on the net will also look to replace he master cylinder , i don`t have a lot of confidence having to squeeze the lever twice to get any braking force and have priced the daytona 675 coated pistons and seal kit from Triumph and works out expensive and may cure the problem .
Old 12-26-2012, 06:34 PM   #6 (permalink)
BigDanUK's Avatar
Would this link help you? I just did a quick search -
http://www.ebay.co.uk/itm/TRIUMPH-DA...item416f7a1b87
Old 12-27-2012, 05:18 AM   #7 (permalink)
Main Motorcycle: 02 Sprintona ST
Other Motorcycle: 03 Daytona 955i
Hi I fitted 675 pistons and seals to my sprint I got a set of calipers secondhand of ebay and just used the pistons and seals. They work a treat better than 6 pot calipers i tried those as well. It is not a master cylinder problem as is widely suggested.
Happy New Year Paul
PaulM is offline   Reply With Quote
Old 12-27-2012, 11:52 AM   #8 (permalink)
Main Motorcycle: '08 Sprint
Other Motorcycle: '07 Ducati 1098S
The EBC HH pads make a huge difference in stopping power so maybe give that a try first if you haven't already. My '08 came with a 5/8" master cylinder and although the lever felt firm, the braking power was lacking for me, especially during two-up riding.. I switched it out for a 14mm M/C, which made enough of a difference in power to make me happy, which I'll admit isn't easy! I can now lock up the wheel with 2 fingers. The downside is a mushy feel to the lever. So to me, it was worth trading a powerless "wood" feel for a spongy one-finger brake. They fade though 10-15 minutes into a track session, so I upgraded to wave rotors, hopefully that will help with that problem. It all depends on what you're looking for from your front brake. The photo is my caliper with Ti hardware.
Last edited by elevens; 12-27-2012 at 12:25 PM. Reason: oops - hh pads not ss pads!
elevens is offline   Reply With Quote
Old 12-27-2012, 12:14 PM   #9 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
I really can't imagine a Brembo caliper being an improvement if you have to add an aluminum bracket to get it onto the forks. I went the 6-pot route and never looked back; EBC HH pads.
Cheers,
-Kit
Old 12-27-2012, 12:24 PM   #10 (permalink)
Legend
Main Motorcycle: '07 Bonneville
Haggis's Avatar
Other Motorcycle: Sprint RS
Originally Posted by DeanRider View Post
Is it really so hard to use the Google Search facility at the top right hand of this page?[/i]
Yes! Because it's at the top left!
It's cheaper and just as effective to do the Tokico swap too.
Haggis is offline   Reply With Quote
Brembo brake caliper bolt jimmyboypike Speed Triple Forum 2 08-28-2012 11:57 AM
T309 Front Brake Caliper Help/Advice Snyderj8 T3 Sport / Touring Forum 4 07-16-2012 07:39 PM
Brembo decals for Brembo brakes horse86 Speed Triple Forum 24 05-28-2012 01:11 PM
Front Caliper Overhaul Advice Tbird95 Maintenance & Workshop Talk 10 05-10-2005 10:03 PM
