955i starting problems - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 12-17-2012, 10:03 PM Thread Starter
Main Motorcycle: 2010 triumph speed triple
I have a 2000 triumph 955i sprint rs. It will not start when cold. You have to actually heat the engine before it will start. The vaccuum ports on the intake will blow compression out of them also. Once the engine is above 100 degrees it will crank and run great. Somebody help me please!!
Cooper69 is offline
post #2 of 4 (permalink) Old 12-17-2012, 11:36 PM
Main Motorcycle: Sprint RS,Black,04
frider's Avatar
Other Motorcycle: That one
Extra Motorcycle: Yorkie and Silky WOOF!!
Valve clearances ok??
particularly inlet.............?????
( assuming cutout switches/horn crimp/battery etc have all been checked)
Chocolate Food of the Gods!!!!!!
frider is offline
post #3 of 4 (permalink) Old 12-17-2012, 11:42 PM
DEcosse's Avatar
Sounds like inlet valves are tight
But regardless of that in TuneECU increase the enrichment factor in the warm-up map at the lower temps
They tend to be lean anyway - you might benefit by increasing the CO trim - that feature is not available to adjust until temp is at full operating (>85C)
DEcosse is online now
post #4 of 4 (permalink) Old 12-18-2012, 09:19 AM Thread Starter
Thank you. I will try these things out.
Cooper69 is offline
starting problems hard starting Fkran Speed Triple Forum 18 01-11-2012 08:33 PM
2000 955i starting problems. aaronblue Daytona Deliberations 2 09-19-2010 10:59 AM
starting problems tomsdad Triumph SuperSports 2 10-11-2008 05:57 AM
Problems starting pyro_ Triumph SuperSports 2 07-20-2006 10:51 AM
starting problems retrobiker Air Cooled Twins Talk 8 10-30-2005 07:44 PM
