Wont run - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 12-04-2012, 06:20 PM Thread Starter
Main Motorcycle: Sprint ST
Wont run
So, went to leave work today, bike wouldn't crank, so I got a jump from my friends jeep. Ride the bike most of the way home, get an ABS light about 1.5 miles from home, 1 mile from home bike quits. Push it to the nearest gas station (thankfully these things push easy), call my friend, throw a jumper on it, wait a few minutes, gets it to re-fired and book it back home. About when I pull in the ABS light comes back on. Won't re-fire. Put the charger back on it, get it to fire, no voltage rise, in fact running around 11V.
I'm thinking charging system, but not quite sure best way to check? and anything else I can check?
OHHHHHH, just had a Sprag Clutch issue (was able to fix that one, the plate popped off the back) and checked the valves. Bike has about 23k miles on it.
redrider7202 is offline
post #2 of 11 (permalink) Old 12-04-2012, 06:57 PM
Main Motorcycle: 08 Pacific Blue Sprint ST
caddydaddy's Avatar
I'd guess that your regulator/rectifier has failed.
I'd start with this thread for diagnosis:
http://www.triumphrat.net/speed-trip...r-upgrade.html
2008 Sprint ST 1050 ABS - Pacific Blue
caddydaddy is offline
post #3 of 11 (permalink) Old 12-04-2012, 08:35 PM
Main Motorcycle: 2011 Sprint GT
Daddy Mac's Avatar
Other Motorcycle: 2013 Husqvarna TE 310
Make sure the ground cable is nice and tight on the battery, give it a good charge and go from there.
Daddy Mac is offline
post #4 of 11 (permalink) Old 12-05-2012, 09:11 AM
Main Motorcycle: Sprint GT 2011 Blue
And make sure your stator connector is not burned.
This guide is great too:
http://www.electrosport.com/media/pd...ng-diagram.pdf
Fred
fredsprint is offline
post #5 of 11 (permalink) Old 12-05-2012, 05:32 PM Thread Starter
Thanks i'll go through that. By the way, anyone know where the charging fuse is?
post #6 of 11 (permalink) Old 12-05-2012, 07:21 PM
Main Motorcycle: '15 Street Triple R
Extra Motorcycle: '70 Husq 360 cross
There is no "charging fuse" on a late model Sprint. There is a 30 amp. main fuse located next to the starting relay under the seat.
Bruce C is online now
post #7 of 11 (permalink) Old 12-06-2012, 06:41 PM Thread Starter
Probably not that then since the bike will start and everything just is running off the batt. Oh well I took tomorrow off so I'll have some fun trouble shooting tomorrow and will keep things posted here
Sent from my LG-E970 using Motorcycle.com Free App
post #8 of 11 (permalink) Old 12-11-2012, 07:26 PM Thread Starter
.... yup R/R... now OEM or refit to the MOSET unit? I had making choices.
post #9 of 11 (permalink) Old 12-12-2012, 12:26 AM
Immoderate Moderator
Main Motorcycle: Black '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
The MOSFET unit will likely last longer and work better, and it's $100 cheaper to boot. Easy call, if you ask me.
Cheers,
-Kit
KitNYC is offline
post #10 of 11 (permalink) Old 12-12-2012, 03:34 AM
Main Motorcycle: 2006 ST
MarkST's Avatar
MOSFET rules, shunt OEM can be bought cheap on eBay but I wouldn't bother...mine left me stranded and humorless 250 mi from home (after just 18k total miles).
I still don't crank right away when the engine is cold. Perhaps stator was cooked?I was warned.
MarkST is offline
You wont believe this Imperial88 Classic, Vintage & Veteran 4 11-03-2008 08:27 PM
You wont believe this! RandyDTFR Sprint Forum 17 07-04-2007 12:33 AM
Here's a 955 that you wont see many like..... kwajazz Daytona Deliberations 17 02-27-2007 09:35 PM
WILL I OR WONT I willo1 Tiger Chat 5 11-15-2005 07:35 PM
