12-03-2012, 01:17 AM
Immoderate Moderator
Site Supporter Legend Main Motorcycle: '04 Sprint RS
Posts: 11,163 Other Motorcycle: 2000 Sprint ST Extra Motorcycle: '77/'82 Suzuki GS550/650
Copper head gasket spray
The more I read, the more I think I need to investigate my oil usage further rather than just getting new rings and assuming that will fix it. I'm thinking I'll pull the head to measure everything at the 72k service, then order whatever parts I need to replace and pull it again.
Obviously, I'd prefer not to replace the head gasket twice, so I'm thinking of using the copper spray from Permatex and reusing the old gasket temporarily. What say you all? Is this the dumbest idea I've ever had, or will the copper spray hold for a couple thousand mile?
Cheers,
-Kit
12-03-2012, 03:35 AM
SuperSport Main Motorcycle: 1999 T'Bird Sport
Posts: 1,319 Extra Motorcycle: 1977 T140
Head Gasket
is most certainly single use only and nothing will retrieve that situation once the torque is taken off it and then the gasket removed. Sorry to be the bearer of bad news.
12-03-2012, 04:01 PM
Supersport 600 Main Motorcycle: 2011 Sprint GT
Posts: 197 Other Motorcycle: 2013 Husqvarna TE 310
Hey Kit
I don't have any experience with reusing head gaskets, but I have used the copper gasket adheasive spray and I can tell you that it works very well. If you're still in the diagnostic phase why not give it a try?
12-03-2012, 04:24 PM
World SuperBike Main Motorcycle: My RED '02 Sprint ST
Posts: 1,991 Other Motorcycle: 99 Thunderbird Sport
I'm with lovecuba on this one...
---Charlie
12-03-2012, 04:27 PM
Formula Extreme Main Motorcycle: Speedtriple!!
Posts: 683 Other Motorcycle: Triumph Trophy 900 Extra Motorcycle: Honda CB400AT
I'm also with the others, remember also the engine has wet liners if they move you'll end up with a sump full of coolant.
Sorry:-(
Sent from my GT-I9100P using Motorcycle.com Free App
12-03-2012, 09:16 PM
SuperStock Main Motorcycle: 2011 Sprint GT
I say go for it. I realize there are heat cycles to take into account, but when you assemble to clay the valves, you don't throw those head gaskets away just because they've been torqued down. Definitely not a permanent solution to anything, but that's not what you're looking for.
12-04-2012, 04:22 AM
Head Gasket
Used head gaskets are always thrown away (unless they are solid copper), just as the workshop manual says.
12-04-2012, 09:09 AM
If it was solid copper they could be reannealed, but if their the same as the 885 engines then their not.
12-04-2012, 06:28 PM
SuperBike Main Motorcycle: '08 Sprint ST
Posts: 1,689 Other Motorcycle: '08 Suzuki SV650K8 Extra Motorcycle: '70 Husq 360 cross
How many dollars and how many headaches have you had with this bike?? Now is not the time to risk another bottom end by saving a few bucks.
12-04-2012, 11:03 PM
SOTP Vintage Series Main Motorcycle: 2006 Blue Thruxton
Posts: 6,368 Other Motorcycle: 06 Thruxton - wife's bike Extra Motorcycle: CB400SF, 4 x DT175, MX80
Normally I'd have a witty thing to say, not this time
Replace it Kit
I used to use Copper spray when I had head trouble on my Leyland Minis. If I ever pulled the head or replaced the gasket I always used the Copper spray. It is an excellent product but I wouldn't use it on a second hand gasket.
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
