Darn, the ABS light did not go out - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear Motorcycle.com Classifieds!
Old 12-02-2012, 08:33 PM   #1 (permalink)
Main Motorcycle: 07 Sprint (ABS)
Any ideas on trouble shooting this and is it possible to interrogate the trouble codes.
07 sprint ABS.
The light normally goes out once you reach 5 or 6 mph.
it immediately came back on and stayed on.
Has stayed on since.
Thanks
kremin is offline   Reply With Quote
Old 12-03-2012, 02:11 AM   #2 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
Other Motorcycle: 2003 Tuono
Check the distance between the abs ring on the rotor to the sensor. When I bought mine, same thing - the previous owner changed the front tire and dropped the wheel beveling the reluctor ring (is that what it's called?). My mechanic removed it and flattened it in his press and after putting it back, all was good in the world. The light went out and the ABS worked again.
2006 Sprint ST 1050, ABS Caspian Blue
2003 Tuono, Magnet Grey
CHECK OUT AIRSTASH.COM!
Rider14 is offline   Reply With Quote
Old 12-03-2012, 09:22 PM   #3 (permalink)
Than got me excited as I just had a new set of tires fitted a week back. unfortunatly it all looks ok
Old 12-03-2012, 09:24 PM   #4 (permalink)
If its not the reluctor ring, check the wires to the sensors. But even a slight bend in the rings will throw it off. Good luck.
Old 12-05-2012, 01:22 PM   #5 (permalink)
Don't trust your eyes. Pull the rings and lay them on a table or flat area. That's the only way to tell. Spinning the wheel while observing the distance b/w the ring and sensor is a good first test...
Good luck.
-Dan
Old 12-05-2012, 09:49 PM   #6 (permalink)
Tried another bike shop. The first one looked and said there were no trouble codes up, then mentioned they were looking at the engine ECU. I didn't enlighten them just went to another shop. These guys knew that there are two ecm's on an ABS model and the trouble code is 1611 - open circuit or short on the front wheel sensor.
Everything looks ok so it will be close inspection from here on in.
One suspicious point is the wiring at the side of the triple clamp, it is in a piece of sleving that appears to be flexing on one point, possibly broken the wires internally.
will post what I find.
Cheers.
Old 12-05-2012, 10:20 PM   #7 (permalink)
champ87's Avatar
Extra Motorcycle: 1973 Yamaha RD350
....is it possible to interrogate the trouble codes.
To read ABS trouble codes from the Nissin ECU you can use a piece of software called DealerTool. If you plan on doing you own maintenance it's also the only way to properly bleed the ABS system as described in this post.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline   Reply With Quote
Old 12-09-2012, 02:27 AM   #8 (permalink)
Thanks for that Champ, have ordered one.
2002 daytona CE fuel light on all the darn time malott442 Daytona Deliberations 27 02-27-2010 12:56 PM
Damn it!!! or should I say Darn it!!! dinkus Sprint Forum 19 12-06-2009 08:53 PM
That darn cat Thunderdude Biker Hang-Out 5 09-09-2009 10:00 AM
Darn Decals! BBDGriptonia Triumph SuperSports 7 03-19-2007 01:33 PM
Darn Triumph QC!! JeffV Sprint Forum 2 01-03-2004 08:45 PM
