Sprrint 1050 starting problem - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com
Old 12-02-2012, 01:15 PM   #1 (permalink)
Main Motorcycle: Sprint ST 1050
Crowman's Avatar
Other Motorcycle: Ducati Monster
Hi All
I had a search through the threads but couldn't find the same problem, so thought I'd ask. My 05 sprint has developed an intermitant starting problem, the starter motor isn't turning, no solenoid noise, nothing, and then sometimes it will start OK. Battery is less than a year old and fully charged. I'm assuming it's probably one of the cutout switches, I've wiggled wires & sprayed WD40 in all the right places, but no change. Any suggestions?
Crowman is offline   Reply With Quote
Old 12-02-2012, 01:55 PM   #2 (permalink)
Main Motorcycle: '08 Sprint ST
Other Motorcycle: '08 Suzuki SV650K8
Extra Motorcycle: '70 Husq 360 cross
Have you physically removed the clutch safety switch from its holder and sprayed contact cleaner onto the visible/exposed contacts??
Bruce C is online now   Reply With Quote
Old 12-02-2012, 07:44 PM   #3 (permalink)
Legend
DEcosse's Avatar
Key-switch is also relatively common problem - broken solder pad on the switch plate, or broken wire in the harness.
Grab the key-switch harness & move it around & see what happens.
Old 12-03-2012, 09:26 AM   #4 (permalink)
Main Motorcycle: Sprint ST 2007 ABS
When I bought mine, it had the same problem. It turned out that the pin that drives the clutch switch had worn a little on the lever. I rotated it a bit, greased it up, and it has been working fine ever since.
uraberg is offline   Reply With Quote
Old 12-03-2012, 01:02 PM   #5 (permalink)
Crowman's Avatar
Thanks for the tips guys, I did check/WD40 the clutch switch as it was my prime suspect. The last mod I've made was to fit the Triumph adjustable levers, so I wondered if it could be to do with that, but with the switch removed and pressed all the way home, it still didn't want to start. I'll check the main switch next. Would the TuneECU software & cable be any help I wonder?
Old 12-03-2012, 04:20 PM   #6 (permalink)
Main Motorcycle: '06 ST ABS
UlsterSpud's Avatar
Other Motorcycle: '88 suzuki Katana 1100
Extra Motorcycle: '09 Bonneville
Try setting your clutch lever at maximum span (# 6 on a Pazzo lever, likely the same on the Triumph one) to allow the plunger to extend fully with the clutch lever pulled. This is a plunger out - not in - switch.
UlsterSpud is offline   Reply With Quote
Old 12-03-2012, 06:37 PM   #7 (permalink)
Legend
DEcosse's Avatar
Originally Posted by Crowman View Post
....but with the switch removed and pressed all the way home, it still didn't want to start. ...
That is wrong way - the switch is closed when the pin is extended, not depressed.
After-market levers can definitely cause the problem - filing a few mm off the end of the pin will make it work across the span range.
Old 12-05-2012, 11:14 PM   #8 (permalink)
Main Motorcycle: 09 sprint, phantom black
Other Motorcycle: 01 Honda VFR 800 FI
Extra Motorcycle: 05 DRZ 400 E, 08 KTM 144
I think I have the same issue with mine. Pazzo levers, and I isolated the clutch switch as the problem. Unfortunately, the switch pieces are now in a baggie, and I have to figure out how they go back together again. Did I mention that there is a spring in there? Lucky for me, I think I have all the pieces. I have been starting her by squeezing the contact leads, then separating them to ride. One more project for this winter. Ride safe, Dave
ontarget is offline   Reply With Quote
Old 12-05-2012, 11:41 PM   #9 (permalink)
Main Motorcycle: Husqvarna TXC250
Other Motorcycle: Sprint ST 1050
Extra Motorcycle: Street Triple
Add the starter button and loose battery connections to the list, too. Personally have experienced both recently, though not simultaneously, resulting in intermittent starting.
Sent from my DROID RAZR
Greg
Vario Windscreen, Kaoko throttle thingy, Trident exhaust, Givi E41 luggage at will......
ioneater is online now   Reply With Quote
Old 12-08-2012, 07:32 AM   #10 (permalink)
Crowman's Avatar
Adjusting the span to 6 didn't help, neither did wiggling the harness by the main switch, the search goes on! (but it's getting a bit nippy in the garage, so it's not an intense search)
My recent experiences working on my 1050 Sprint, and questions about starting problem CBLove Sprint Forum 20 10-19-2012 08:34 AM
Tiger 1050 starting problem britlad Tiger Chat 4 09-04-2012 08:23 AM
1050 starting problem zep1975 Sprint Forum 15 12-08-2011 12:56 PM
2007 triumph sprint st 1050 starting problem ppggmd Sprint Forum 36 11-21-2011 02:27 PM
Srint ST 1050 Starting Problem RonnieD155 Sprint Forum 21 02-21-2011 03:36 PM
