Steamy Situation - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-28-2012, 06:38 PM   #1 (permalink)
Main Motorcycle: 2001 Sprint ST
TripleST's Avatar
Steamy Situation
I noticed some coolant on the ground underneath the Sprint today, so I investigated. There was some paint coming off the radiator around the inlet and outlet hoses as well as it being moist in that area so I suspected a loose clamp, so I tightened them. I cleaned everything and ran the bike to see if anything leaked. I didn't notice any real leaks, but I noticed a wet spot on the radiator itself and a small amount of steam coming out. Two questions: 1) Could this be the source of my problem and 2) Does this mean the radiator needs to come out? Any advice would be helpful.
Thanks,
TST
TripleST is offline   Reply With Quote
Old 11-28-2012, 06:42 PM   #2 (permalink)
Main Motorcycle: 2006 Sprint, Caspian Blue
Other Motorcycle: 2006 FJR
Take it for a ride and get it hot. The fins tend to hold a lot of water as evidenced if you wash the bike and get water in the radiator. Now check for leaks. If you have a hole it will show now its hot.
Fullchat is offline   Reply With Quote
What would you do in this situation? Greaser Biker Hang-Out 59 06-02-2011 03:49 PM
LED situation Russ Club Cafe' 8 04-07-2010 02:43 AM
STEAMY DAY OUT RAT RUN (UK) cully Hinckley Classic Triples 1 05-21-2006 12:14 AM
A Steamy day out or a Dirty night in? TRIUMF3 RAT - United Kingdom 1 05-18-2006 02:21 AM
STEAMY DAY OUT (UK) cully Ride / Trip Reports 0 05-18-2006 02:18 AM
