ticking noise on startup... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Old 11-27-2012, 10:17 AM   #1 (permalink)
Main Motorcycle: Sprint GT
I've noticed a ticking noise for the first few seconds of startup in the cold (below 40f). It almost sounds like a valve tick, but just a single valve. It's hard to tell since it just did this the last 3 startups, but it sounds like it is in time with the engine. After a few seconds it just goes away completely.
Before I talk to my dealer, has anyone had anything like this?
Could I just be due for a valve service a bit early? all motorcycles I've had get tighter over time tho...
It's a 11 Sprint GT, 4500 miles.
2011 Sprint GT, 2008 Kawasaki KLR650, 1981 Honda CB750F, 1986 Honda Shadow VT1100C *sold*, 2006 Kawasaki ZX-14 *STOLEN!!*, 1980 Yamaha XT500 *sold*, 1998 Honda Shadow Aero VT1100C3 *sold*, 2006 Yamaha FZ6 (sold)
buicknick72 is offline   Reply With Quote
Old 11-27-2012, 07:48 PM   #2 (permalink)
Main Motorcycle: 2003 Sprint ST
Other Motorcycle: 1985 Yamaha Maxim-X
Is that a new sound? Was if doing it in the cold before? My first thought is it is that cold, the oil will be thick for a bit after you first start it up. Could be the lifters tapping if oil isn't flowing well.
What weight oil do you have in it?
jvswan is online now   Reply With Quote
Old 11-28-2012, 08:41 AM   #3 (permalink)
Still has the oil from the dealer. It just started, or I just noticed it. I've don't think it's any colder than I've started it up in before.
Old 11-28-2012, 09:25 AM   #4 (permalink)
Well, it could be something to talk to the dealer about. It would be strange if it were a valve issue. I'd be pretty surprised if the valves need adjusting at 4500 miles.
Ticking could be lots of things. My guess is that it's just a cold weather and oil issue. Since you are still on dealer oil, then my first recommendation would be to change the oil and put in a full synthetic like Mobile 1. I think it is 15w-50. You might find a full synthetic with 5w-40 or something, too. Regardless, I suspect that with a brand new engine and who-knows-what oil (could be a partial-synthetic blend) the oil has lost viscosity at 4500 miles and will sound and operate much better with an oil and filter change. The break in period can be hard on any engine oil. So, that should be the first thing to do.
Old 11-28-2012, 12:10 PM   #5 (permalink)
I probably should have said that I bought it from the dealer with 4000 miles already on the clock, it was a demo bike that one of the owners used as their personal bike. It was said to have synthetic in it.
I'm gonna listen to it more carefully, if it is an engine noise I'll do an oil change, if it's still there I'll go visit the dealer.
Old 11-28-2012, 01:26 PM   #6 (permalink)
Main Motorcycle: 06 Sprint ST ABS red
iceman's Avatar
..... possibly an exhaust leak that tightens up as it gets to temp?
A new engine shouldnt have ticking noises due to wear.
Anyhow the dealer is the best one to sort it for you.
Grant
iceman is online now   Reply With Quote
Old 12-16-2012, 01:35 PM   #7 (permalink)
Main Motorcycle: 2006 Sprint St abs
Be careful with manifold bolts.
In another post, the man thought a tick was a leaky manifold gasket and snapped the stud off in the head. If you have a leak there replace all three gaskets.
Never blindly tighten anything that isn't obviously loose. Always use a torque wrench on everything you can. If you over tighten steel into AL hard blindly, it will either crack the AL, strip it, or snap. Generally, when things get too loose, snugging back to torque may work only if you catch it right away. The gasket is usually ruined and could be how it became loose, not the other way round. Over tightening is never a fix. Trouble is, people don't realize how much mechanical advantage they are applying to things with tools until it is too late.
A manifold leak is easily felt with your hand and may leave carbon tracks any way.
Turned out that bike had an electrical leak at a coil, snapping/ticking as it grounded yet the thing ran fine. Dilectic silicone grease is a handy item in any tool box but won't fix a cracked coil.
I agree, change the oil.
You don't want to leave dirty oil in over the winter anyway.
It may be too thin and draining off the parts when it sits.
My experience with car dealers ? They would turn up the radio. Hope your bike dealer has a smart mechanic. Mention it just in case it seizes in the guide or blows a valve throught the head, then you've mentioned it.
Yes, change the oil and I bet it goes away.
mdlark is offline   Reply With Quote
Old 12-16-2012, 03:12 PM   #8 (permalink)
Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
oldndumb's Avatar
Other Motorcycle: 05SV1K, 2012 Ducati M1100
Good post.
I would like to add that snugging back to torque is best done by loosening first, and then re-torquing.
Oldndumb
Caveat lector
Old 12-17-2012, 10:27 AM   #9 (permalink)
It does it kinda random. Temperature doesn't seem consistent. It almost sounds more like a chain rattle, but it's for such a short time it's hard to tell. Still have to change the oil. Will keep updated.
Old 12-18-2012, 03:50 AM   #10 (permalink)
Main Motorcycle: 2005 Sprint RS 955i
Snoops's Avatar
Other Motorcycle: ZRX1100 - 97 Trident 900
Extra Motorcycle: Trophy 1200
Originally Posted by buicknick72 View Post
. . . I bought it from the dealer with 4000 miles already on the clock, it was a demo bike . . .
For goodness sake, why are you even thinking about messing about with it yourself?
Surely it's still under the manufacturers warranty, so if theres anything amiss, just take it back to the dealer to sort out.
Fair enough if you'd bought it privately with 50000 miles up, but this is a nearly new, very low mileage bike with a warranty.
Take it back & get them to listen. If theres anything wrong, they should fix it - and for free.
Snoops is offline   Reply With Quote
Ticking noise when ticking over finkelstein Tiger 1200 - Mods & Workshop 2 08-16-2012 03:26 AM
Ticking at startup BSUCardinalfan Street Triple Forum 12 10-21-2011 02:23 PM
Ticking noise Help! ds6380 Speed Triple Forum 10 07-21-2010 02:30 PM
ticking noise hinkleyboy Triumph SuperSports 5 09-10-2005 01:56 PM
Engine Noise at Startup Speed Triple Forum 0 08-06-2004 07:11 AM
