Soft Clear Coat? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 11-26-2012, 03:32 PM   #1 (permalink)
Main Motorcycle: Sprint GT
Other Motorcycle: 2000 Suzuki Katana
Soft Clear Coat?
Is it just me or is the clear coat on the Sprint GT a little on the soft side?
Astro4X4 is offline   Reply With Quote
Old 11-26-2012, 03:59 PM   #2 (permalink)
Main Motorcycle: 2010 Rocket 3 Touring
Tripps's Avatar
Other Motorcycle: 78 CB750K, 02 Sprint
Extra Motorcycle: 80 BMW r65/sidecar
IDK, but the clearcoat on my Rocket Touring is the softest I've ever seen on any bike, anywhere. Guess it's a Triumph thing....
The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge. - Daniel J Boorstin
Tripps is offline   Reply With Quote
Old 11-27-2012, 12:55 AM   #3 (permalink)
Main Motorcycle: 08 Sprint ST
phdean's Avatar
My ST is the same. I have a magnetic tank bag and I can now see an impression (the size of the magnets) of the rubber from the bottom of the bag in the clear coat! That's crazy soft! Never had a bike that did that before, it's very disappointing.
phdean is offline   Reply With Quote
Old 11-27-2012, 09:14 AM   #4 (permalink)
Main Motorcycle: 2008 Sprint ST
Other Motorcycle: 2008 Yamaha FZ1N
Clear usually stays fairly soft unless it is wet sanded and buffed. Leaving it soft resists chipping. Whenever you paint a car if you can lay it down smooth never buff it.
2008 Sprint ST 1050
Heated Grips, Tail Tidy, D&D Exhaust, TOR Tune, Power Bronze Double Bubble Screen, 520 Chain Conversion W/ 18/42 Sprockets, GSX-1300R 6-Piston Front Calipers, Smoked Integrated Tail Light.
B5.5_Passat is offline   Reply With Quote
Old 11-27-2012, 09:50 PM   #5 (permalink)
Main Motorcycle: '08 Sprint ST - Red
pmackie's Avatar
Other Motorcycle: '02 Bandit 600S
Extra Motorcycle: '87 Honda CR250R
My '08 Sprint clear coat picks up the black colour from my Alpine Star leathers...so, I installed the paint protection kit from Tank Slapper.
http://www.thetankslapper.biz/index.html
The tankslapper film also picks up the black dye, but I remove the film every so often, and clean it well. Goo Gone works well to remove all of the dye, but soap and water takes most of it off during regular washing.
ex bike mechanic - late 70's somewhat rusty
29 years in the fuel/lubes industry
pmackie is offline   Reply With Quote
Old 11-30-2012, 05:40 PM   #6 (permalink)
I think I'm going to grab a paint protection kit for my bike.
Old 11-30-2012, 06:50 PM   #7 (permalink)
Main Motorcycle: 2011 Sprint GT
HeyGriff's Avatar
+1 with Astro4x4.
I had my tank wrapped earlier in the summer by a local guy here in the Peoria, IL area. I'm happy I did. Looks great. Most people don't realize it's been wrapped. These are the guys that did my tank.
www.max-shield.com
I might even have the saddlebags done next summer. Keeps the chain lube, road rocks, bugs and my boots from scuffing the paint. I gave the guy $100 bucks. That was labor and the 3M film material. It took him an hour and half. He never had wrapped a Triumph tank before. I pulled the tank-bag power ring and seat off the bike. He had to figure how he was going to deal with the shape of the Sprint GT tank. He used three separate pieces of material to cover the tank.
He was quite knowledgeable about the film. The 3M material does not block UV light. This allows the exposed paint and the paint under the film to fade equally. He said, " Factory paint is not harmed by the application and removal of the film." He also said, "there was no warranty against a "repainted surface paint damage" when it comes to removing the film. This is due to the fact that paint adhesion varies greatly to the base material due to less than perfect paint techniques. He did follow up that he has removed film from many repainted surfaces with no damage. He said he uses some low heat and a lot of time and patience.
He used a very sharp razor knife, a hand blow-dryer and a spray bottled,filled with distilled water, alcohol and (I think) a literal "drop" of soap, to act as a lubricant/surfactant when he did my tank. It was fun to watch him work his magic.
He told me he wrapped a very expensive bi-turbo Porsche, that's in the Peoria area, with 100% film coverage. He does a lot of film wrapping for new car dealers selling the higher end auto's.
One test is worth a thousand "expert" opinions!
Curiosity was framed,ignorance killed the cat
HeyGriff is offline   Reply With Quote
What clear coat to spray? mr1bienvenu Twins Technical Talk 5 09-04-2011 09:19 AM
Soft clear coat 12004 Tiger Chat 4 01-30-2011 03:05 PM
Engine Clear Coat GySchmit Twins Technical Talk 7 09-06-2010 10:58 AM
clear coat Jim Z Blues Classic, Vintage & Veteran 11 02-26-2010 09:27 AM
Clear coat peeling off? Reppyboyo Speed Triple Forum 6 03-12-2008 10:56 PM
