11-20-2012, 03:19 PM
#11 (permalink)
World SuperBike Main Motorcycle: My RED '02 Sprint ST
Posts: 2,067 Other Motorcycle: 99 Thunderbird Sport
Originally Posted by XL1200R
Personally, I just buy bikes with new batterys and sell them before they go dead. Don't have to worry about any of this crap.
I'm the same way about cars, getting rid of them when the ashtrays fill up.
I seem to be keeping them longer these days...
oh yeah, maybe quitting smoking had something to do with that
---Charlie
11-20-2012, 04:39 PM
#12 (permalink)
SuperStock Main Motorcycle: 2011 Sprint GT
With cars, it's usually a big deal if I have to buy a set of tires!
Thinking back, I've only bought one car battery and one bike battery in my life.
11-20-2012, 05:51 PM
#13 (permalink)
Site Supporter Commentator Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
Posts: 9,035 Other Motorcycle: 05SV1K, 2012 Ducati M1100
Shorai literature states the cells are capable of 80% discharge without damage. That works out to 12.86vdc.
You might be able to resuscitate it, but at 7.5vdc, it probably will not be reliable due to reduced capacity. Lead acid batteries also lose capacity when undercharged.
Oldndumb
Caveat lector
11-20-2012, 06:16 PM
#14 (permalink)
Site Supporter SuperBike Main Motorcycle: 08 Pacific Blue Sprint ST
This Shorai is toast!
I put my Battery Tender on it last night and left it on all day while I was at work. I checked the voltage just now, and it was 13.3. I turned the ignition key to run and the voltage dropped to 9.0 volts in about 30 seconds! Not even enough to start it.
I still have my old battery, so I guess I'll have to swap that back in and then figure out why the Shorai discharged.
What sucks the most is that the weather is perfect for riding! It was in the low 70's and not a cloud in the sky! Go figure!
2008 Sprint ST 1050 ABS - Pacific Blue
11-21-2012, 03:20 AM
#15 (permalink)
Site Supporter Supernova Main Motorcycle: 2011 Sprint GT 1050
Posts: 21,806 Other Motorcycle: 2004 Daytona 955 Extra Motorcycle: Previously - Many
Caddydaddy
have you checked what charge you are getting and have you fitted the reg/rec and wiring upgrade?
Cheers
Dave
11-23-2012, 05:44 PM
#16 (permalink)
Originally Posted by DaveM
Caddydaddy
Cheers
Dave
I swapped in my old battery today, since the Shorai has voltage, but no cranking power. It is not charging, just battery voltage when running.
I checked the R/R and it is fine. I checked the voltage coming from the stator and it is 0!
Is 27,000 miles kind of low for one to go bad? I was reading about how they can look charred when bad, but it doesn't look too bad.
Are there any recommendations for a new stator?
11-23-2012, 08:29 PM
#17 (permalink)
Immoderate Moderator
Site Supporter Legend Main Motorcycle: '04 Sprint RS
Posts: 11,300 Other Motorcycle: 2000 Sprint ST Extra Motorcycle: '77/'82 Suzuki GS550/650
Rick's is the only reasonable option for a replacement stator. Electrosport is junk, from extensive personal experience, and OEM is crazy pricey.
http://ricksmotorsportelectrics.com/...JpbnRTVDEwNTA=
They won't always look bad when they're fried, and sometimes a working stator can look pretty charred.
I wouldn't necessarily trust the R/R until you're getting proper voltage out of it with a new stator; they're very hard to fully test.
Cheers,
-Kit
11-23-2012, 09:23 PM
#18 (permalink)
Cheers,
-Kit
Thanks! I did see Rick's while doing a search, and the $140 vs. $504 for a new Triumph part is a HUGE difference!  I just can't believe it failed so soon!
I am going to upgrade the R/R with a MOSFET unit. Might as well get the whole charging system squared away, now that I have the bike torn apart.
11-23-2012, 09:50 PM
#19 (permalink)
eBay seller Jasonmotoelectrix has the best price I've been able to find on the MOSFET units. No affiliation, just a customer whose dissatisfaction has nothing to do with the seller or the product.
Cheers,
-Kit
11-24-2012, 08:03 PM
#20 (permalink)
Hi CD I don't know if this an option for you in the Sates but I got my Daytona Stator rewound, and it works perfectly.
When my Daytona stator bit the bullet it was because of my reg/rec and my stator was very burnt looking too.
Cheers
Dave
