Old 01-10-2006   #1 (permalink)
hem-fir
Gentlemen,
Thanks for your moderately helpful replies to my question several weeks back about how to install the Kisan headlight modulators. After pondering the problem for a couple weeks (raining here in the Northwest constantly anyhow) I dove in and ten minutes later, problem solved. No need to remove a single part from the bike.
How: Reach below the instrument panel and pull the three-pin connectors off the back of the two headlights, plug them into the two Kisan modulator units, then plug the lot into the back of the bulbs. The Kisan electric eye (that turns the modulation off at night) has a two-part harness that plugs into the bottom of each modulator. One plug goes into the "master" unit; the other into the "slave."
I thought about where to drill a 10mm hole for the electric eye and ended up taping it to the clutch cable for now. If I drill It'll probably be into the lower corner of the instrument panel (below the bar).
Result: works fine and if it irritates cagers or other bike riders all the better. They'll see me.
Old 01-11-2006   #2 (permalink)
Favorite Bike: 2002 Triumph Sprint ST
Panthers_Den's Avatar
Other Motorcycle: Future: Blue '08 D675
nice, I plan to get me one of those as well as the tail light modulator too
'02 Sapphire Blue Sprint ST
My Photo Album
My Archived Photo Album
www.myspace.com/panthers_den
Panthers_Den is offline   Reply With Quote
headlight modulators DannyChrist Twins Talk 12 08-26-2006 06:27 PM
Question for those who have installed aftermarket headlight brackets JG Twins Technical Talk 1 07-12-2006 02:58 PM
Light Modulators Bikernoob The Rocket Science Forum 1 09-22-2005 12:37 AM
Modulators anyone? SpiderTex Sprint Forum 15 12-08-2004 03:03 AM
Headlight Modulators? Knightshade Speed Triple Forum 1 04-18-2004 06:49 PM
