Brake caliper seal direction
I havent been able to find an answer on this. When replacing brake caliper seals the manual says to fit them with the wider side outermost. Both the new seals, from Powerhouse in the UK, and the seals already fitted do not seem to have a wider side?
I've tried to determine if there is a wide side but with no luck.
How do you work this out?
Thanks
