ST 1050 high bars on ST 955 ?. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.com
Old 11-10-2012, 11:30 AM   #1 (permalink)
Newbie
Main Motorcycle: Sprint ST 955i
Other Motorcycle: Trident 750
I have a 2003 ST 955 and find the bars a bit low (after a few hours in the saddle at back road speeds I get bad wrist ache).
Does any know if the ST 1050 high bars will fit on the 955 ?.
Has anyone tried this ?
- do the higher bars mean the throttle cables housing fouls the RH fairing
- do the clutch & throttle cables, and brake pipe, have to be changed
thanks
stephengrenfell is offline   Reply With Quote
Old 11-10-2012, 01:28 PM   #2 (permalink)
Main Motorcycle: 08 Pacific Blue Sprint ST
caddydaddy's Avatar
I believe they share the same bolt pattern, so other than the cables, it should work fine.
2008 Sprint ST 1050 ABS - Pacific Blue
caddydaddy is offline   Reply With Quote
Old 11-10-2012, 02:49 PM   #3 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Right on the money caddydaddy although some fine filing or dremel work is often required and cables rerouted or lengthened as required.
There is at least 3 or for different height bars if you include the RS which has the lowest as std.
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 11-10-2012, 05:04 PM   #4 (permalink)
Newbie
OK. Sounds like it's worth pursuing then.
Thanks for the replies.
ST high bars Slymon Sprint Forum 6 08-15-2012 11:23 PM
high bars on S4? punkrockish Triumph SuperSports 7 08-06-2011 01:07 AM
high bars or not !!! ynotbiker Daytona Deliberations 16 09-11-2009 10:46 AM
Weigh in: low bars vs high bars elevens Sprint Forum 23 06-23-2009 08:53 AM
high bars tango Trophy 0 05-22-2005 05:12 PM
