GT Chain adjust - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-07-2012, 07:08 AM   #1 (permalink)
Main Motorcycle: GT Sprint
GT Chain adjust
The way to adjust the chain on the GT I just bought looks the same as the 955i. Looks like the same tool.
Today, after 400 ODO miles, I adjusted the chain. It took forever!! The spanner barely grabs and is always slipping off.
Is there a better spanner tool or better procedure to adjust the chain???
Thanks
J-sport
sportsprint is offline   Reply With Quote
Old 11-07-2012, 07:34 AM   #2 (permalink)
Main Motorcycle: 04 RS SSSA
Mickea's Avatar
Extra Motorcycle: KLR 250
Not quite sure what you mean.
The tool isn't the best however after the securing nut is loosened the eccentric cam adjuster should move fairly easily, easily enough for cheapo C spanner to move it?
Good luck Mick
Mickea is offline   Reply With Quote
Old 11-07-2012, 09:39 AM   #3 (permalink)
Main Motorcycle: 2011 Sprint GT
XL1200R's Avatar
I had the same issues, with the spanner slipping off. Just took some patience. THe hub itself moved freely.
(plus Ontario and Québec) Visit my riding blog at AllSeasonRider.com
XL1200R is offline   Reply With Quote
Old 11-07-2012, 05:52 PM   #4 (permalink)
Main Motorcycle: Sprint ST 1050
Check out Ebay for an aftermarket improved version
Pcdabbler is offline   Reply With Quote
Old 11-08-2012, 01:40 AM   #5 (permalink)
Chain Adjusster
The tool provided to adjust the chain on the GT Sprint is not as good as previous models.
I have resorted to using a pin punch (very carefully).
BazzaST is online now   Reply With Quote
Old 11-08-2012, 07:28 AM   #6 (permalink)
Since I previosuly owned a 955i ST, I did compare the two adjusters. I agree that the older adjuster is better made.
I am going to modify my GT wrench in the following manner....
The first is to weld the handle to the tool. Then, I am going to weld washes to the side of the spanner. Braze is more correct.
After observing how this tool slips off, it appears to slip off to the side. By adding "thickness" to the wrench, this will push against the sprocket and at least hold the gadget on the sprocket.
Yes, I have the pinch bolt full loose. With 400 miles only, this area is very clean. I am not anticipating many chain adjustments, but when I have to do one, I want it to be easy to do.........J
Old 11-08-2012, 09:43 AM   #7 (permalink)
Main Motorcycle: '08 Sprint ST
Other Motorcycle: '08 Suzuki SV650K8
Extra Motorcycle: '70 Husq 360 cross
Don't get too carried away with welding washers to the side of the tool!! When you have the spanner correctly on the adjuster, the heads of the sprocket bolts will just clear the wrench.
Bruce C is offline   Reply With Quote
Old 11-08-2012, 09:59 AM   #8 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
There's at least one eBay seller with a stainless version that's much better than stock. Same c-spanner as the Ducati 1098 and several others. I bought one of these tools from this seller (bsanut) a few years ago; no complaints here:
http://www.ebay.com/itm/Triumph-Chai...b10299&vxp=mtr
Cheers,
-Kit
Old 11-08-2012, 10:15 AM   #9 (permalink)
I just placed my order for this adjusting tool. $34 including shipping. The stock adjuster was so difficult to use.
J
Old 11-09-2012, 07:55 PM   #10 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
For me at least I never noticed any difference between my "04 Sprint ST adjuster and my "04 Daytona adjuster or my 2011 Sprint GT one.
I also don't have a real problem adjusting my chain with the std cheese tool supplied in the tool kit.
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
How I adjust my chain ArferBrick Hinckley Classic Triples 13 11-03-2012 11:48 AM
Need Chain and Sprocket? re:can't adjust chain mjonesjr8 Daytona Deliberations 8 10-13-2010 08:10 AM
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 12 06-17-2010 04:30 PM
Help With Chain Adjust WardenRoss Sprint Forum 2 06-26-2007 08:50 AM
ST Chain Adjust TXRyder Sprint Forum 7 03-13-2006 09:05 PM
