Painting Fuel Tank - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 11-05-2012, 03:40 AM   #1 (permalink)
Main Motorcycle: Sprint ST!
Grae_ST's Avatar
Painting Fuel Tank
Hi All,
Hoping someone with way more knowledge about paints/painting can point me in the right direction.
I'm planning on re-painting the Sprint, so can anyone tell me the best way of stripping the old paint from the plastics? and more importantly, the fuel tank! as it's an 2007 and has the 'Nylon' tank. Is there any special prep. needed for stripping the old paint and equally any special prep. needed before applying the new coating?
I won't be doing the work myself, just trying to educate myself a little so that i'm asking the paint shop guys the 'right' questions!
Any other suggestions/ideas are welcome.
Paint will be 'slightly' custom... keeping the basic 'Black' but going with a different colour metallic flake.
Seeing as I can't buy a 'New' ST and there's nothing else on the market currently, that fires my blood, going to turn the ST into a long term project. No clue how long... but should be good for a few laughs along the way!!! Stay tuned.... lol
Cheers, G
I may not have gone where I intended to go, but I think I have ended up where I intended to be.
- Douglas Adams
Grae_ST is offline   Reply With Quote
Old 11-05-2012, 04:01 AM   #2 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Long time no see and looking forward to seeing your new paint job mate
cheers
Dave
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 11-05-2012, 04:38 AM   #3 (permalink)
Grae_ST's Avatar
G'day Dave,
Yup, been a while.... Life has been intruding... slowly gotten on top of it... still a few hurdles to get over in the next 9mths or so... but if all goes well... should be back to (relatively) plain sailing soon after!!
I'll add pics as i go along... should be entertaining... going to throw a complete GSXR front end on (wheel, brakes etc.) as well as a few other mods... as budget permits...
Cheers, G.
- Douglas Adams
Old 11-05-2012, 07:14 AM   #4 (permalink)
You rarely have to strip the paint off in order to refinish unless it has already had mulitiple paint jobs or there is a problem with the existing finish. Stripping down to bare plastic would require a large amount of extra unneeded work along with treatment with an adhesion promoter. Normally, the paint is sanded, sealed, and repainted with no issues. Proper preparation in any hard to reach areas is needed to make sure adhesion is good and tank should be completely stripped of all hardware and fittings, then rinsed out so no possibility of gas fumes remain. Paint hardener may need adjusted since few shops would be willing to bake or heat cure the tank in their booth. Overall though, painting bike pieces is pretty easy and you can do a large amount of the prep yourself. Good luck, sounds like a fun project!
18/43, Two Bros exhaust, K&N, MFW pegs, Sonic springs with Valving by Tmod, rebuilt rear shock from Traxxion (waiting), risors waiting for new brake lines.
IN10SS is offline   Reply With Quote
Old 11-05-2012, 07:35 AM   #5 (permalink)
Main Motorcycle: My RED '02 Sprint ST
CharlieS's Avatar
Other Motorcycle: 99 Thunderbird Sport
I like to sand the previous paint with 220, removing the clear and a lot of the basecoat with a DA sander. I want to leave some so I can get it 320 smooth before I spray with primer/sealer. I use the white dupont stuff, before painting with basecoat/clearcoat. That gave me a really good match on the old 02 red sprint. 320 smooth is what I used to do before paint years ago. It was nice to find out I could still get away with that. Paint now-a-days is so much better and easier to work with....
---Charlie
CharlieS is online now   Reply With Quote
Old 11-05-2012, 04:29 PM   #6 (permalink)
Main Motorcycle: 2003 Sprint ST
Other Motorcycle: 1985 Yamaha Maxim-X
Most auto parts places around here sell aircraft stripper. Stuff is a liquid that will pull off paint pretty well. That's I'd you do want to strip the paint first.
jvswan is offline   Reply With Quote
Old 11-05-2012, 07:43 PM   #7 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
Jvswan, is that aircraft stripper safe for the plastic tank?
Cheers,
-Kit
Old 11-06-2012, 04:06 AM   #8 (permalink)
Paint stripper
Normal paint stripper will melt the plastic on your tank and any other plastics.Their are strippers made to remove paint on plastic surfaces , but even then you must use it with caution as not all plastics are the same and can react differently to different plastics.As mentioned earlier it is unnecessary to strip back all the paint unless it is damaged or cracked and even then you can still sand back the damaged areas to a feather edge than use a Hi-fill primer wich will fill in any imperfections.
rustybolt is offline   Reply With Quote
Old 11-06-2012, 11:16 PM   #9 (permalink)
You can get some stuff called Klean-Strip (aircraft paint stripper) that is made for plastic parts. They have multiple formulas. The normal stuff is for metal. Make sure to get the plastic version. I haven't used the plastic one, but the regular metal one works great.
Old 11-07-2012, 02:49 AM   #10 (permalink)
Supernova
DaveM's Avatar
I think I would be contacting Acerbis the tank manufacturer and checking what chemical strippers are safe to use with their product.
http://www.acerbis.it/images/cat/pdf..._fueltanks.pdf
cheers
Dave
painting a tank deadman Hinckley Classic Triples 12 07-11-2010 08:26 AM
Painting tank Big B Twins Technical Talk 9 09-02-2007 10:44 PM
Painting gas tank... brownbomber Twins Talk 11 05-30-2007 08:20 PM
Painting the tank crambuster Maintenance & Workshop Talk 2 05-15-2007 03:43 PM
Painting the tank RatNYC Twins Talk 5 04-22-2006 08:20 AM
