11-06-2012, 03:12 AM
#11 (permalink)
Speedo problem again
Hi Kit, if the speedo shows speed when turning backwards, I suppose that the sheet metal part with the 2 teeth in the frontwheel could be damaged too.
Juergen
11-06-2012, 03:15 PM
#12 (permalink)
Powerbike Main Motorcycle: My Y2K ST
Originally Posted by KitNYC
Vielen dank, Juergen! I'll be in touch if it tests bad.
Thanks, thap8riot. I just don't understand how the sensor could've been damaged, as it's been several months and thousands of miles since I've touched the front wheel.
Also, here's an additional data point: the speedo registers moving backward just as it always has; it's only moving forward that's glitchy.
Cheers,
-Kit
I don't remember how long mine took to go bad. I know that the 2 teeth were bent and not in the magnet slots but were still turning the magnet. It took a while for the pressure to crack the magnet. Again, I don't remember how long that took, but it may have been several weeks and 1000 or more miles. Let us know what you find.
If I say something that can be taken two different ways, and the one way made you mad, then I meant the other one.
11-10-2012, 10:10 PM
#13 (permalink)
Immoderate Moderator
Site Supporter Legend Main Motorcycle: '04 Sprint RS
Posts: 11,148 Other Motorcycle: 2000 Sprint ST Extra Motorcycle: '77/'82 Suzuki GS550/650
Well, this seems to be why my speedo was erratic:
Note that the edges of the cracks obviously used to line up, but are much too worn to do so any more. I've dressed the driven edges with a file until I can spare the cash for one of Juergen's alloy/neodymium rings; it works for the moment.
Cheers,
-Kit
11-23-2012, 09:10 PM
#14 (permalink)
Well, dressing the edges of the magnet with a file worked for about 50 miles.
I got the part from Germany today and it worked great, for six miles.
Time to look at the drive ring, I guess...
11-24-2012, 08:26 AM
#15 (permalink)
Did you put grease to the ring from all sides?
11-24-2012, 02:42 PM
#16 (permalink)
Yes, lots of grease. I'm about to go pull it apart again; I'll try to get some pics as well.
Cheers,
-Kit
11-24-2012, 05:01 PM
#17 (permalink)
Greasy speedo ring:
Drive ring in hub:
Drive ring out of hub and cleaned up:
More drive ring:
Drive ring straightened, drive edges dressed w/ file:
The new magnet ring is locked up tight inside the sender housing. It will not move.
11-25-2012, 08:30 AM
#18 (permalink)
Please take a photo from the cleaned ring in the housing. I sold more than 50 of them in 2 years and nobody mentioned any probs, so I am very interested in a solution and to find out the reason. Can you move the ring with force?
Juergen
11-25-2012, 06:07 PM
#19 (permalink)
11-26-2012, 03:15 AM
#20 (permalink)
It seems, that the drive ring has overrun the grooves in the magnet ring and deformed it. I think, the straightened drive ring will work right with a new magnet ring. I'll send a new one for free.
Juergen
