Sprint Clutch Return Spring - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 10-28-2012, 07:03 PM   #1 (permalink)
Main Motorcycle: Sprint ST 955 (1999)
Hi,
On my Sprint ST 955 (1999), I've noticed that the Clutch return spring, which is attached to the clutch lifter arm that goes into the gearbox, is not actually fastened or tensioned on the arm. I'm guessing that it should be tensioned onto the arm to givethe clutch cable a return tension.
However, I noticed that the spring on a new Triumph Tiger was actually the same, which has me perlexed as to the function of this spring.
Has anyone got any clues on this spring, and what it should do ?
Attached is a photo.
OEGRider is offline   Reply With Quote
Old 10-28-2012, 07:08 PM   #2 (permalink)
Main Motorcycle: '08 Sprint ST
Other Motorcycle: '08 Suzuki SV650K8
Extra Motorcycle: '70 Husq 360 cross
Look like the springs bottom hook is broken off!!
Bruce C is offline   Reply With Quote
Old 10-28-2012, 10:33 PM   #3 (permalink)
I thought the same as well Bruce, but when I checked out the spring on the new Triump Tiger it was exactly the same as mine....
Old 10-29-2012, 10:43 AM   #4 (permalink)
Main Motorcycle: My RED '02 Sprint ST
CharlieS's Avatar
Other Motorcycle: 99 Thunderbird Sport
Your spring is broken. So is mine. I don't think it matters...
---Charlie
CharlieS is online now   Reply With Quote
Old 10-29-2012, 03:31 PM   #5 (permalink)
OEGRider
This is what the lower point of connection of your clutch spring should look like. Note that it is hooked around a nub that is cast into the clutch cover.
Sprint Clutch Return Spring-img_1362.jpg   Sprint Clutch Return Spring-img_1365.jpg
Old 10-29-2012, 05:31 PM   #6 (permalink)
Hi Bruce, thanks for the photos. I can see now how the spring is fitted and that mine is broken. Much appreciated. I agree that it doesn't matter that much, the clutch still works ok, but I'll get it replaced anyway.
Old 01-05-2013, 09:53 PM   #7 (permalink)
Main Motorcycle: 2008 Speed Triple
Did you get this replaced? Did you remove the cover?
kalonji is offline   Reply With Quote
Old 01-06-2013, 12:29 PM   #8 (permalink)
Main Motorcycle: '06 ST ABS
UlsterSpud's Avatar
Other Motorcycle: '88 suzuki Katana 1100
Extra Motorcycle: '09 Bonneville
It's easy to bend a new hook using needlenose pliers. I did this some 2 + years and 60,000 Km ago and it's still OK. I believe the original hook had too sharp a bend causing a real stress point so I used a larger radius for my rebend. Worth a try before pulling the cover to replace.
UlsterSpud is offline   Reply With Quote
Old 01-06-2013, 05:41 PM   #9 (permalink)
Yes, I did get a replacement spring, but the hassle of removing the cover isn't worth it.
UlsterSpud, thanks for the tip about bending a new hook using the old spring, I'll give that a go !
Old 01-07-2013, 12:19 PM   #10 (permalink)
Other Motorcycle: '07 Ducati 1098S
When I was very young and terrorizing the neighborhood on a 1958 Cushman Eagle "motorcycle", my kickstand spring broke. As my friend's dad told me, "A spring ain't sprang until it's sprung". That applies to this day
elevens is offline   Reply With Quote
Kickstart Return Spring Fraggle Classic, Vintage & Veteran 4 08-23-2010 08:58 PM
Brake spring return arm smac Twins Technical Talk 14 12-09-2007 05:59 PM
Clutch Return Spring ocgeorge Sprint Forum 2 05-10-2007 10:15 AM
clutch return spring tri955i Daytona Deliberations 2 04-26-2007 05:12 PM
Shifter return spring miketango The Rocket Science Forum 8 06-29-2006 03:24 PM
