Originally Posted by miataman92
I've bled the brakes and added some fluid.
I see your bike has ABS. Did you follow the recommended
procedure for bleeding the ABS system or did you just bleed the same way as non-ABS and hope for the best?
How many miles should I expect to get out of this chain?
From what I've seen on this forum 20,000 - 30,000 miles is typical. My '06 Sprint has 46,000 miles and I've just fitted my second
replacement chain and sprockets although I've read more than one report from owners who've done that mileage on the original.
If the chain should need to be replaced, is there a recommended aftermarket replacement?
The stock DID chain (DID 50(530)VM X-Ring Chain) is good. A suitable chain from any of the major brands will be fine so it might just come down to price or even personal preference.
