BikeBandit
Old 01-07-2006   #1 (permalink)
What's the power output of the '05 and/or '06 Sprint Alternator?
Thanks
[ This message was edited by: TiggerTwo on 2006-01-07 22:25 ]
OAK
TiggerTwo is offline   Reply With Quote
Old 01-08-2006   #2 (permalink)
trafficfixr's Avatar
as far as i know, all alternators are supposed to output 14.4 volts. cant help with the maximum amperage.
[ This message was edited by: trafficfixr on 2006-01-08 07:04 ]
Many people think my Tona is a Ducati when they first see it. I tell them nope, this is way faster than any Duc.
trafficfixr is offline   Reply With Quote
Old 01-08-2006   #3 (permalink)
Favorite Bike: '01 Bionic Bonnie
ggRAT's Avatar
35 Amps
According to the owner's manual Page 109:
Electrical Equipment
Battery.....................12 volt, 12 amp-hour
Alternator.................12 volt, 35 amp-hour
Headlight..................2 x 12 volt, 60/55 watt H4 halogen
Tail/Brake Light.........LED Display
Turn Signal Lights......12 volt, 10 watt
[ This message was edited by: ggRAT on 2006-01-08 08:12 ]
GO:904cc/-AB/-AI/K&N/Jets:140,45,-1.5,3mm/Predators/ceramic headers/180 rear/Ohlins/Works/520+19Tx43T
SHOW:Pazzo levers/Gaiters/Oberon pegs/new lights/SS braided cables/68 flyscreen,seat & cowl Old & New Pics
ggRAT is offline   Reply With Quote
Old 01-08-2006   #4 (permalink)
I appreciate the info.
OAK
Old 01-08-2006   #5 (permalink)
ggRAT's Avatar
Here's the ENTIRE 2005 Sprint ST Specifications section from the Owners Handbook. Enjoy. (Copy/Paste using Courier New 9pt font and it will line up nicely.)
=========================OWNERS HANDBOOK Page 107=========================
DIMENSIONS
Overall Length ................. 83.2 in (2114 mm)
Overall Width................... 29.3 in (745 mm)
Overall Height.................. 48.3 in (1228 mm)
Wheelbase....................... 57.4 in (1457 mm)
Seat Height..................... 31.7 in (805 mm)
WEIGHTS
Dry Weight ..................... 462 lbs (210 kg)
Maximum Payload................. 473 lbs (215 kg)
ENGINE
Type ........................... In-line 3 cyl.
Displacement ................... 64 cu in (1050 cc)
Bore x Stroke .................. 3.11 x 2.81 in (79 x 71.4 mm)
Compression Ratio............... 12,0:1
Cylinder Numbering.............. Left to Right
Cylinder Sequence Number........ 1 at left
Firing Order.................... 1-2-3
Starting System................. Electric Starter
PERFORMANCE
Maximum Power*.................. 123 bhp (125 PS) at 9,250 rpm (*DIN 70020)
Maximum Torque.................. 77ft.lbf (104 Nm) at 5,000 rpm
LUBRICATION
Forced Lubrication (wetsump)
=========================OWNERS HANDBOOK Page 108=========================
COOLING
Coolant Type.................... Mobil Antifreeze
Water/anti-freeze ratio......... 50/50
Coolant Capacity................ 0.60 US gal (2.3 litres)
Thermostat Opens (nominal)...... 85-88C
FUEL SYSTEM
Type............................ Electronic Fuel Injection
Injectors....................... Twin let Solenoid Operated Plate Valve
Fuel Pump....................... Submerged Electric
Fuel Pressure................... 43.5 psi (3.0 bar) nominal
FUEL
Type ........................... 89 (R+M)/2
Tank Capacity .................. 5.55 US gal (21 litres)
IGNITION
Ignition System................. Digital Inductive
Electronic Rev Limiter (r/min).. 10,900 (r/min)
Spark Plug...................... NGK CR9EK
Spark Plug Gap.................. Gap 0.7 mm
Gap Tolerance................... +0.05/-0.1mm
TRANSMISSION
Transmission Type............... 6 Speed, Constant Mesh
Clutch Type..................... Wet, Multi-Plate
Final Drive Chain............... DID X-Ring Endless
Primary Drive Ratio............. 1.750 (105/60)
Gear Ratios:
Final Drive Ratio............... 2.211 (19/42)
1st............................. 2.773 (15/41)
2nd............................. 1.947 (19/37)
3rd............................. 1.545 (22/34)
4th............................. 1.292 (24/31)
5th............................. 1.154 (26/30)
6th............................. 1.074 (27/29)
=========================OWNERS HANDBOOK Page 109=========================
TIRES
Tire Pressures (Cold):
Front....................... 36 psi (2.5 bar)
Rear........................ 42 psi (2.9 bar)
Approved tires/sizes:
Front....................... Bridgestone BT020 NN 120/70ZR17
Rear........................ Bridgestone BT020 NN 180/55ZR17
WARNING: Use the recommended tires ONLY in the combinations given. Do not
mix tires from different manufacturers or mix different specification
tires from the same manufacturers as this may result in loss of motorcycle
control and an accident.
ELECTRICAL EQUIPMENT
Battery ........................ 12 volt, 12 amp-hour
Alternator ..................... 12 volt, 35 amp-hour
Headlight ...................... 2 x 12 volt, 60/55 watt H4 halogen
Tail/Brake Light................ LED display
Directional Turn Signal Lights.. 12 volt, 10 watt
FRAME
Castor.......................... 24 degrees
Trail .......................... 3.54 in (90 mm)
TIGHTENING TORQUES
Oil Filter...................... 7.37 lb/ft (10 Nm)
Oil Drain Plug.................. 18.43 lb/ft (25 Nm)
Spark Plug...................... 8.85 lb/ft (12 Nm)
Rear Wheel Eccentric Clamp Bolt. 36.86 lb/ft (50 Nm)
=========================OWNERS HANDBOOK Page 110=========================
FLUIDS AND LUBRICANTS
Engine Oil...................... Semi or fully synthetic 1OW/40 or 15W/50
motorcycle engine oil which meets
specification API SH (or higher) and ]ASO
MA, such as Mobil 1 Racing 4T
Brake and Clutch Fluid.......... Mobil Universal Brake & Clutch Fluid
DOT4
Coolant......................... Mobil Antifreeze
Bearings and Pivots............. Mobil Grease HP 222
Drive Chain..................... Mobil Chain Spray or Mobilube HD 80
power output from the alternator brgtiger Tiger Workshop 4 10-05-2007 08:44 AM
alternator output okiecityflash Classic, Vintage & Veteran 3 04-15-2007 08:45 PM
alternator output of S3... TiggerTwo Speed Triple Forum 2 01-08-2006 12:44 AM
Alternator Output Trophy 1 10-27-2004 08:55 AM
Alternator output Hinckley Classic Triples 2 04-20-2004 01:47 PM
