Clear Indicator Lenses - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 11-03-2012, 02:02 AM   #31 (permalink)
Main Motorcycle: Black 09 Sprint ST
MrMessy's Avatar
I totally agree with this idea of chrome bulbs and think ill do it myself just to ge tthat last bit of orange out :P
MrMessy is offline   Reply With Quote
Old 11-06-2012, 02:25 PM   #32 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
Other Motorcycle: 2003 Tuono
Still nothing from China...
2006 Sprint ST 1050, ABS Caspian Blue
2003 Tuono, Magnet Grey
CHECK OUT AIRSTASH.COM!
Rider14 is offline   Reply With Quote
Old 11-06-2012, 11:05 PM   #33 (permalink)
Well, I got them today and when installing the left side, when I couldn't get he mirror out of the assembly, I took my hands away and the mirror dropped. Yes, it's cracked.
Anyone know where to get a left mirror without having to buy the entire mirror assembly?
Lens covers look good and fit perfectly.
- Dan
Old 11-06-2012, 11:14 PM   #34 (permalink)
Main Motorcycle: 2011 Triumph Sprint GT
JohnD's Avatar
Other Motorcycle: '08 Kawasaki Concours 14
Rider14,
You may have more luck and spend less if you take your mirror to a window glass/mirror store and have them cut you a new mirror. Grab your Yellow pages or Google and check it out.
JohnD is offline   Reply With Quote
Old 11-07-2012, 03:21 AM   #35 (permalink)
MrMessy's Avatar
Rider14 its your lucky day .
I have my spare mirror from the wrecked arm i bought to scab the mirror post from, so if you PM me your addy im happy to post it over to you at no cost - happy to know its been put to good use .
So you know it exists and the shape its in :
(P.S. it looks like a chip in the first pic but its just a reflection of the corner of the window frame :P)
Old 11-07-2012, 08:45 AM   #36 (permalink)
PM about to be sent!
Old 11-08-2012, 02:37 AM   #37 (permalink)
MrMessy's Avatar
Received .
Old 11-08-2012, 03:06 AM   #38 (permalink)
Main Motorcycle: Triumph Sprint GT 2011
Recieved mine today
So if I have understood correctly. To install
1. Remove 2 screws under the mirror assembly
2. Remove the mirror. (Is it snapfit? Do i need to pry?)
3. Remove 2 screws backside of lens.
4. Remove orange install clear and mount everything again.
Sodan is online now   Reply With Quote
Old 11-08-2012, 07:14 AM   #39 (permalink)
MrMessy's Avatar
Mirror has the two screws (clearly :P) and a point at the top of the post the mirror attaches to at the top. To remove, undo screws and pivot the mirror toward the bike as you pull the base down and toward you. Dont use force here, if force is needed you are doing it wrong, and its fairly easy to damage the post.
The bulb, do it before the lens, dont use tools to grab or pry as its easy to rip/cut the rubber, just grip the base with your fingers and pull it out and towards you. May take a bit of force, but itll come out!
The lens is easy, two screws, self explanatory.
Only trick for fitting is to make sure the rubber is pushed into the new lens properly - a pair of pliers so you can exert even pressure on both sides of the bulb base thingy helps here, AND make sure you get the little tip of the mirror post back into its spot before you push the base of the mirror post in .
Its really straight forward. There may be a little hesitation on the first one but the second will take like 2 minutes....
Old 11-08-2012, 08:43 AM   #40 (permalink)
Okay thanx alot!
Just to make sure "a point at the top of the post the mirror attaches to at the top"
By post you mean mirror post or the housing of the mirror? So you shoul pivot the mirror in the adjustment and "slide" it downwards? Is the adjustment mechanism supposed to come out with the mirror aswell or should the mirror detach from it?
Maybe I am owerly worried about this and it is obvious once starting? I have fair amout of mech experience.
Clear indicator lenses for GT Steve gb Sprint Forum 3 07-26-2012 12:02 PM
Clear Indicator Lenses? Leigh_at_ch9 Cruisers - America, Speedmaster 5 02-20-2012 10:32 AM
Clear Indicator Lenses Mutley Tiger Chat 18 05-28-2011 07:20 AM
07 Sprint ST 1050 clear indicator lenses/yellow bulbs ? whoosh Sprint Forum 13 06-15-2007 06:37 AM
