Originally Posted by Gatorman
Bad fuel sender should trigger that.
If you replace it do a search on fuel fittings (replace them with metal - e.g., Colder) and problems with fiberglass tank swelling (so much the mounting bolts don't line up).
Had the joys of dealing with both when I replaced mine.
As far as I know the earlier fuel tanks are Plastic made by a Acerbis they are not fibreglass.
They have been commonly used on Triumph's and Ducati's.
Triumph's and Ducati's in the USA have often reported blistering and other problems since the high usage of ethanol fuels.
Latter models changed to steel.
AFAIK anyhow.
