Really?!?! Now, the head gasket? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old 07-09-2012, 05:01 PM   #11 (permalink)
Main Motorcycle: 11' Duc Multi Touring S
jfusaro's Avatar
Other Motorcycle: 09 Bonnie Se
Extra Motorcycle: Kabota L 3130 HST
Report it stolen and buy a Vespa
jfusaro is online now   Reply With Quote
Old 07-09-2012, 05:22 PM   #12 (permalink)
Main Motorcycle: Hinckley Bonneville,ST
Other Motorcycle: Scrambler 900, Bonneville
Extra Motorcycle: 1050 ST WOWER
Originally Posted by KitNYC View Post
Vitesse, your post came about the same time the truck driver pulled over because he had failed to properly attach the bike to to the flatbed...
I have just begun to drain the sump. The oil drain bolt is just cracked, and, well, they say a picture is worth 1,000 words:
What sort of warning would you have expected?
The bike has just over 67k, which means this engine is at about 50k.
Cheers,
-Kit
When a head gasket is relatively "thick" (old copper based, mostly auto application) you have a gradual sputtering and misses to the point of dropping a cylinder, that is with a larger "gap" when the gasket is breached.
With these new (ish) ultra thin gaskets the gap forced through the gasket would be very small thus a more gradual indication that the seal had been compromised.
The coolant doesn't even look mixed as if it simply flooded the sump immediately.
If there was a catastrophic crack in the head this could happen but for a head gasket to fail that quickly, entirely and cleanly is a real mystery.
I used to see plugs with a crystallization on the electrode that showed seepage of coolant into the chamber.
I really do hope you get some relief and somehow get back on the road.
vitesse is online now   Reply With Quote
Old 07-09-2012, 07:21 PM   #13 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
Yeah, may not have been the head gasket...
Interior of timing cover:
Bottom of drain pan:
Old 07-09-2012, 07:26 PM   #14 (permalink)
Main Motorcycle: 09 Sprint ST ABS
Billbikes's Avatar
Other Motorcycle: Lemond Zurich
No look good!
09 Sprint ST-Trident exhaust,rear fender tidy.
You can take the boy out of Texas, but you can't take Texas out of the boy.
Billbikes is online now   Reply With Quote
Old 07-09-2012, 07:29 PM   #15 (permalink)
Main Motorcycle: 800 Roady
Cburt's Avatar
Is this your second motor on this bike?
If so, that's not a glowing recommendation of reliability for Triumph.
Cburt is offline   Reply With Quote
Old 07-09-2012, 07:31 PM   #16 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Geez Kit sorry to hear this. are they bits of bearing shell?
All the best with what ever it is Kit.
Dave
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 07-09-2012, 08:28 PM   #17 (permalink)
Is that a gear tooth, upper right in the round drain pan?
Old 07-09-2012, 08:48 PM   #18 (permalink)
Main Motorcycle: 2006 Speedy
maxorbit's Avatar
Other Motorcycle: none
The coolant doesn't even look contaminated. It's green whereas the coolant for my 1999 is blue.
Maybe you can consider a cheap and dirty head gasket job?If it's the head gasket.
** returned home after a successful mission in Mexico
Unemployed for the rest of my life
My garage is all Euro now.
maxorbit is offline   Reply With Quote
Old 07-09-2012, 09:32 PM   #19 (permalink)
Legend
KitNYC's Avatar
The first motor was still good when replaced, aside from being an oil burner and having a large chunk missing from the sump where a piece of cinder block hit it. Can't fault Triumph for that. (This one going at 50k, though...)
Dave
Thanks, Dave. No idea what it is, besides part of something that's supposed to still be in one piece.
That's the timing cover from the right-hand side of the motor, not a drain pan. The inner area on that is maybe an inch around?
I drained the factory blue out of this a long time back. The oil looks slightly contaminated, but only slightly. The coolant is clean 'cause it dumped in about the same time the motor stopped spinning, else it would've gotten mixed in with the oil. Maybe the head gasket was leaking a little, but the vast majority of the coolant went into the sump all at once when a relatively large hole got added somewhere.
Anyway, not just a head gasket. I don't think this motor's gonna spin again.
Cheers,
-Kit
Old 07-09-2012, 10:10 PM   #20 (permalink)
Main Motorcycle: 2005 Triumph Sprint ST
Ouch
Ouch. Sorry to hear that Kit.
Is this before or after your 25% glycol/75% Water Wetter change?
http://www.triumphrat.net/sprint-for...d-coolant.html
If after, I guess we have a terrifying answer to BRG-BIRD's question, "Does the water wetter alone give adequate corrosion protection?" "Nope. Corrodes straight through."
TheEnglishGuy is offline   Reply With Quote
Head Gasket GTR Classic, Vintage & Veteran 1 04-14-2012 09:45 AM
Head gasket? aceface Speed Triple Forum 5 03-31-2012 09:15 AM
900. Head gasket? Cracked head? Ideas??? Boom T3 Sport / Touring Forum 4 06-18-2011 05:53 PM
bad head gasket twowheelscott Speed Triple Forum 2 01-05-2009 12:08 PM
