Old 12-10-2005   #1 (permalink)
just picked up my rs yesterday from the dealer after 3 1/2 weeks to fix speedo and check battery. one guy started it and rode 30' to the truck, then shut it off. i went to start it this morning and it cranked a few seconds and was dead. i've had it on the charger all day and it will not start, just for maybe half a second. i smell gas and would like to pull the fuel pump fuse and crank it to blow out engine but have no idea which fuse it is. can anyone tell me? what is procedure for starting a flooded bike? they didn't bother to check the battery... it keeps going dead. needs a battery imo. j
jellero is offline   Reply With Quote
Old 12-10-2005   #2 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
jellero,
if it was convenient I'd get her back to the dealer somehow. Stlakid or Don might have some clues.
good luck, can't be to serious.
davem
DaveM is online now   Reply With Quote
Old 12-11-2005   #3 (permalink)
jellero,
i signed on this morning to tackle the same problem on my 03 st. i was planning on eating lunch with pack, went out and climbed on it (40 degrees out) and it would not start. i also smelt gas and also ran battery down. i was thinking the same as far as stopping the fuel pump so it would dry out. i hope you can get a response (for you and me). ride safe.
draft1 :???:
I feel more like I do now than I did when I first got here!
draft1 is offline   Reply With Quote
Old 12-11-2005   #4 (permalink)
40!!?? geez it was 5 earlier. i have a small box heater blowing on engine now and the charger going for a few hours.
i had a mazda rx-7 that flooded out all the time. i would just pull the fuel injector/pump fuse, crank it, relace fuse it started right up.
it takes the whole day to get to the nearest dealer and i am convinced they either don't listen or don't know what they are doing. suppose your problem is a battery not holding a charge. charging system checks out fine and no current drain can be found in bike. so what does that leave? (hint- i told them the battery had been tested and FAILED locally, plese test there). they "tested" it by parking bike in warehouse for 1 1/2 weeks and it started... i need a battery.
good luck. j
Old 12-11-2005   #5 (permalink)
I'm just getting used to the sprint I got for the wife,it to is hard to start cold but trial has led to this procedure. crank for five to ten seconds twice, walk away for about a minute go back turn it on hit starter and this one will fire immediately. this has worked every time down to five degrees F. hope it helps. PS cranking more than ten seconds at a time appears to be counter productive.
[ This message was edited by: flatspins on 2005-12-11 09:59 ]
If you don't stand behind our troops, Please feel free to stand in front of them.
flatspins is offline   Reply With Quote
Old 12-11-2005   #6 (permalink)
well, i give? coudn't get it to start and have loaded it on the pickup to take to dealer. i have 5 days remaining on waranty so i figure this is best. i hope it is something minor.
draft1
Old 12-11-2005   #7 (permalink)
draft, if you find out please let me know and also which fuse controls the fuel. i got mine nice and warm and got the shop to 70+ all day, still nothing. even had a friend tow me behind his bike!! doesn't even pop anymore.
of course, the harley started right up, kick start too. j
Old 12-11-2005   #8 (permalink)
(fuel pump and starter share the same fuse... i should have left the ignition off while being towed, then turned it on after drying out the engine. next time.) j
Old 12-13-2005   #9 (permalink)
jellero,
took the bike in monday, still waiting on results. will keep you posted here as soon as i find out something.
draft1
Old 12-13-2005   #10 (permalink)
draft, the shop is open on a monday?? i pulled plugs and dried the engine, cleaned and tested plugs and got it going (posted in "engine light on"). it will be interesting to see what your dealer says. i don't think it is a good idea to start f.i. bikes when they are cold and shut them off still cold. j
Starting with carbs flooded?? kidkazi Twins Technical Talk 3 06-10-2007 06:45 AM
Engine Serial Number location? whodkne Speed Triple Forum 2 03-06-2007 11:03 PM
difficulty starting engine zmann Speed Triple Forum 33 06-15-2006 01:41 PM
2004 S3 - Blown fuse on starting mrober Speed Triple Forum 4 10-09-2005 08:42 AM
engine cutting out, starting probs Scardi The Rocket Science Forum 3 08-22-2005 02:23 AM
