I have a masters degree on this topic as I have had to replace 3 of them. The first came (RH) before the first service. They replaced it underwarranty. The second (LH)went out about 4000 miles, this time I replaced it, though they gave it to me free under warranty. The third, time it was the LH side again at about 20K.
I tend to think they have threee problems. One, the contact adhesive. Two, the plastic frame material is brittle. Three, the fastener will break the plastic if you overtighten it. So be carful when installing it. You might also put a little grease on the machined screw as mine had a little corrosion on it. On all three of mine, the black frame cracked around the fastner, this crack dislodge the lense (over time) from the frame at the glue line. It was really apparent on the last one. Just a crappy light IMHO.
Fishtale
